Street Bob tail light
Old 03-19-2010, 03:13 PM
Fever's Avatar
Fever
Fever is offline
Stage II
Default Street Bob tail light
I'm new to the forum and would really appreciate suggestions. The big ugly chrome tail light on my black denim Street Bob makes cringe.
I really liked the setup on my former Nightster with the turn signals doubling as the brake lights with the plate mounted on the swing arm. Does anyone know of anyone that offers a conversion kit etc...to do something like that or similar? I'm open to other suggestions too. Thanks!
Old 03-19-2010, 03:16 PM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
Cycle Visions Eliminator plate. It has built in signals too. You can toss your stock signals. I can get you one if you like.
Old 03-19-2010, 03:42 PM
tscreener's Avatar
tscreener
tscreener is offline
Default yes
Do a search on the forum they make a kit to use turns as runing lights, brake lights and turnsignals. Then get the license plate holder.
Old 03-19-2010, 05:50 PM
HDDyna2006's Avatar
HDDyna2006
HDDyna2006 is offline
Hd 69462-06a $57
Old 03-19-2010, 05:56 PM
phatman's Avatar
phatman
phatman is offline
Um..... ur bob should have duel filament bulbs from the factory. You just need to remove that ugly light & fill the hole or chop your fender.
Old 03-19-2010, 06:06 PM
Vinsil's Avatar
Vinsil
Vinsil is offline
THIS:
PLUS:
With a little:
and finally some:
Will get you this:
But yes, you can just unplug that light, fill in the hole/chop fender and the sigs will remain as brake/turn from the factory. I plan to removed my painted and cut tail light and chop the fender here in the next few weeks to clean up the rear even more. Good luck!
Old 03-19-2010, 06:12 PM
bberck's Avatar
bberck
bberck is offline
I thought they still had single element bulbs but came stock with the run/turn/brake module?
Old 03-21-2010, 11:37 AM
Fever's Avatar
Fever
Fever is offline
Stage II
BBerck,
How did you eliminate the OEM tail light on your Super Glide?
Old 03-21-2010, 11:46 AM
ghostrider69's Avatar
ghostrider69
ghostrider69 is offline
If it is like my 09 SB then all you have to do is remove the taillight and chunk it. Your sigs will work as run/sig/brake. Because it came from the factory with the module already installed.
Old 03-21-2010, 06:17 PM
bberck's Avatar
bberck
bberck is offline
Originally Posted by Fever
BBerck,
I put on a run/turn/brake module from biketronics then I had a body shop fill the taillight hole and paint the fender. I redid all the wiring in the back end to clean up the unneeded wires.
oldguyriding
06-29-2021 08:32 PM
Protocol
04-04-2019 12:23 PM
ALstew
Stock Harley Take Offs
12-17-2015 03:49 PM
Skyking75
05-25-2009 02:43 PM
carsnot4me
09-07-2007 05:06 PM
Quick Reply: Street Bob tail light
