Front brake problem
Old 03-09-2010, 06:22 PM
hawgwerkz's Avatar
hawgwerkz
hawgwerkz is offline
Stage IV
Default Front brake problem
The front brake has been bled and feels fine, wait an hour and check it and it will be fine until you move the bike and hit it and the lever will come back to the grip
Old 03-09-2010, 06:26 PM
Johnnyiroc's Avatar
Johnnyiroc
Johnnyiroc is offline
sucking air from some place? thats my guess. If there are air bubbles in there still, they will cause this. Try a cable tie around the lever holding the lever over night. I have heard many times this gets air out of the lines. I have a bike that you can bleed and they feel fine, but it goes a little soft after you ride. Tried the lever trick and it worked. Had to crack the cap open gently overnight also. Make sure you dont have a leak that you may have missed.
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
Does it grab the rotor or not? It sounds like either there is still air in the line or something is not sealed all the way. I had a bike that had an invisible crack in the MC and it did the same thing.
Old 03-09-2010, 06:28 PM
07 dyna man's Avatar
07 dyna man
07 dyna man is offline
did u take the front tire off the bike or this just occur
Old 03-09-2010, 07:46 PM
shake rattle n roll's Avatar
shake rattle n roll
shake rattle n roll is offline
sounds to me like the seals are buggered in the master clyinder..
I have in the past tested them in cars pickup trucks by pumping up the brakes and holding them...then slowly backing off on the amount of force applyed to the pedal...to find that it will at some poind start to drop(seals are shot and seal at high pressure but leak at low)
should work just as well on your bike.
Hope i was of some help
Old 03-09-2010, 07:50 PM
Johnnyiroc's Avatar
Johnnyiroc
This bring up a thought...I had a car that would corner so hard the end play in the axles would cause the rotor to push the piston back into the calipers in the rear brakes. On a hard turn , hit the brake it went nearly to the floor, second application it was back 100%. Could your wheel be loose a little or have some end play in the axle or spacers?
shake rattle n roll
Sorry for the double post herre...I need to learn to read more closely
While the test i told you works ...Im wondering now ?
You got a bent rotor ? it might kick the brake pads way back resulting in what you describe the first time you try them... or even multiple times as long as the bikes moved
Should also pulse on your leaver if thats it
Old 03-09-2010, 08:13 PM
hawgwerkz's Avatar
hawgwerkz
Stage IV
We did just put a new tire on
Old 03-09-2010, 08:24 PM
hawgwerkz's Avatar
hawgwerkz
Stage IV
No pulse in the lever
Old 03-09-2010, 08:28 PM
shake rattle n roll
prehaps the spacers got mixed up ?
Mine has a longer one on one side
short of that i just dont know
Quick Reply: Front brake problem
