New Lifters
New Lifters
Will there be a 10-30min waiting while adjusting SE adjustable pushrods, if the lifters are new?
I followed the instructions, adjusted the rods to zero clearance (i.e. no play up & down) and after the 2.5turns I can turn the rods immediately. <I did soak the lifters over night in oil>
Any help would be appreciated!
Thanks
Thanks
Thanks for the replies on the lifter question. I had thought that soaking was worthless as well, however figured it won't hurt. I have another question.
I installed SE adjustable Pushrods when installing my 255 (in retrospect I wish I had just took the tank off and reused the stock PRs).
My question is, I currently have them set to 2.5 turns everywhere I read the ideal number of turns if 3-4 for a 24 TPI adjustable pushrods. My goal is to readjust to 3.5turns to reduce the valve/lifter noise. Now they are already installed at 2.5turns and I have already started the engine (on this past Sunday) When I readjust the pushrods, on this coming Saturday, do I have to prime the lifter after backing the pushrods off? I would only assume that I would however no one ever discusses priming?
The way I think about it is if the total lifter range is .200 and 2.5turns is approx right in the middle at .100 (utilizing a 24tpi PR) then when i back off my pushrods the lifter will already be at .100. Meaning unless I prime the lifter again (pushing the lifter to its highest point, when i take the PR to zero lash and turn it 3.5turns I'll be down at the bottom of the range and essentially at .200 (i.e. the end of the travel for the lifter). Actually, with 3.5 turns I'll be beyond the travel and pushing up the valves. This is theory even slightly correct?
To be honest, I am getting a headache reading all the posts on adjustable PRs I am 50% there in just buying Prefect Fit PRs and saying screw the whole thing....
Any thoughts would be greatly appreciated!
Tank removal isn't necessary, at least on an '07. Just block it up 1-2" and that's enough. The only hassle of reusing the stock pushrods is removing and re-installing a few of the rocker-cover and rocker-plate bolts, which are hard to access. I would say it increased the time required maybe two hours in total.
My question is, I currently have them set to 2.5 turns everywhere I read the ideal number of turns if 3-4 for a 24 TPI adjustable pushrods. My goal is to readjust to 3.5turns to reduce the valve/lifter noise. Now they are already installed at 2.5turns and I have already started the engine (on this past Sunday) When I readjust the pushrods, on this coming Saturday, do I have to preload the lifter after backing the pushrods off? I would only assume that I would however no one ever discusses preload?
The way I think about it is if the total lifter range is .200 and 2.5turns is approx right in the middle at .100 (utilizing a 24tpi PR) then when i back off my pushrods the lifter will already be at .100. Meaning unless I preload the lifter again (pushing the lifter to its highest point, when i take the PR to zero lash and turn it 3.5turns I'll be down at the bottom of the range and essentially at .200 (i.e. the end of the travel for the lifter). Actually, with 3.5 turns I'll be beyond the travel and pushing up the valves. This is theory even slightly correct?
Ah sweet thanks man, I just figured I'd have to start from the zero position and go from there but I guess that makes sense as well. I am going to try 3 and probably stop there. I also just ordered a baisley spring to increase oil pressure so we'll see how that works as well.
