Sponsored by: Jekill and Hyde
case boring?
Old 03-05-2010, 08:09 AM
hyPerhog's Avatar
hyPerhog
hyPerhog is offline
Default case boring?
case boring what all is done when you have that performed? i saw a piston kit that said must have case boring done? i need some schooling thanx in advance.
Old 03-05-2010, 09:27 AM
beaureed445's Avatar
beaureed445
beaureed445 is offline
With your bike coming with a stock 96", anything over 107" would need case boring. They literally bore the area of your cases where the pistons come through to accomodate the larger diameter.
Old 03-05-2010, 10:48 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
We have been boring cases for over 20 years.
The cases are split, and set up in a vertical mill, on a 90* precision angle plate, machined just for that application, square with the quill, and indicated dead nuts on center.
If using an Axtell 4 1/8" cylinder, a 2 step boring process then is established, and the dimensions are held to their exact specs.
Once that is completed, the center hole is then machined thru to the lifter side, and their proprietary hardware is then used.
Usually what follows that, is also a Timken bearing conversion in the left case half, as long as the crank is running true.
Scott
__________________
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Maxton Mile World Record
4500 sq ft. facility
See us on Facebook.
Old 03-05-2010, 11:00 AM
splitting_lanes's Avatar
splitting_lanes
splitting_lanes is offline
The cases are split, and set up in a vertical mill, square with the quill, and indicated dead nuts on center.
Scott
and it don't cost that much to send your cases to New York either... :^)
Old 03-05-2010, 07:04 PM
hyPerhog's Avatar
hyPerhog
hyPerhog is offline
thanx guys for the information.. i understand now.
Old 03-05-2010, 07:25 PM
GONZO6's Avatar
GONZO6
GONZO6 is offline
Default Boring Job
Remove and disassemble engine.
Gut the block and reassemble the 2 halves.
Mount in milling machine, level, and center on the case bore.
Chuck up proper tooling, cut to desired diameter.
And as mentioned, a second step cut is done where necessary.
A twin cam A block goes like this.
Old 03-05-2010, 07:36 PM
Hillsidecycle.com
Sponsor
Those cases look MIGHTY familiar.
Old 03-05-2010, 10:28 PM
FLSTF's Avatar
FLSTF
FLSTF is offline
That's where mine are headed come Monday morning.
Old 03-06-2010, 07:11 AM
hyPerhog's Avatar
hyPerhog
hyPerhog is offline
couldnt you just shorten the piston skirts and save a lot of time?
Old 03-06-2010, 07:39 AM
Kingofcubes's Avatar
Kingofcubes
Kingofcubes is offline
No, you wouldn't have any skirts left. The factory has taken the o-ring out of the new cases around the locator dowells so we no longer step bore the cases.
Quick Reply: case boring?
