ape hanger install
Old 03-04-2010, 11:34 PM
Soldier's Avatar
Soldier
Soldier is offline
Default ape hanger install
are they real hard to do? I am not all that enclined but i have a brother in law that can work on cars that may be able to give me a hand. I just dont want to get to far over my head
Old 03-04-2010, 11:39 PM
archergodwin's Avatar
archergodwin
archergodwin is offline
Depends on how you want to do your install... things such as internal wiring add complexity to the mix. Do your homework about the parts you'll need, and then think about how much time it would take you to do it... then double that.
There is a bunch of help on the forum here if you hit a snag.
Biggest thing to think about if you're not inclined is the tools. Does the B-in-L have a good set of tools?
Old 03-05-2010, 02:22 AM
carltex's Avatar
carltex
carltex is offline
One thing if you don't go over the mini ape height bars you don't have to lengthen the wires. There is enough excess under the tank to reach.
Old 03-05-2010, 05:33 AM
jss1975snow's Avatar
jss1975snow
jss1975snow is offline
Its not that hard, I pulled ape install off without a hitch, and I was a rookie. Make sure you do your homework.
Old 03-05-2010, 06:47 AM
shimmon's Avatar
shimmon
shimmon is offline
https://www.hdforums.com/forum/dyna-...e-install.html
https://www.hdforums.com/forum/dyna-...some-apes.html
check these links out. the second link has a bunch of other links to check out. it should be fairly easy if you take your time and what not!
Old 03-05-2010, 08:55 AM
m i k e's Avatar
m i k e
m i k e is offline
Do it
Old 03-05-2010, 09:00 AM
SC-Longhair's Avatar
SC-Longhair
SC-Longhair is offline
If the OP doesn't go over the 'mini-apes height', then is he really installing apes as he inquired about.
The the OP: I'm no mechanic but swapping bars is not hard at all. It does take a little time to do. ~4-6hrs.
Run the wires internally. It'll look like crap if you just zip-tie them to the bars.
Old 03-05-2010, 10:55 AM
Soldier's Avatar
Soldier
Soldier is offline
I got a site from a post on here that has a kit that they say are already pre wired and set up. I think this may be the way I have to go.
Now I just have to figure out how I am going to get the clamp and risers on my lowrider (idiot lights)
Old 03-05-2010, 10:57 AM
SC-Longhair
Soldier, I know Hill Country Custom Cycles on eBay sells prewired kits. I think the premium for that is too much. It's not hard pulling the wires yourself...for free.
Old 03-07-2010, 07:17 PM
ponch3640's Avatar
ponch3640
ponch3640 is offline
Not that hard to to unless you have to change out wires and cables then its just alittle harder but still not bad
Quick Reply: ape hanger install
