Riser bolt size?
Old 07-28-2006, 03:06 PM
CHEESE's Avatar
CHEESE
CHEESE is offline
Default Riser bolt size?
I'm going to change out my stock risers for some a little taller. I've seen a few different ones with different bolt sizes. My idea is to use the stock hardware and bushings if possible. What size do I need?
Old 07-28-2006, 08:22 PM
soup48's Avatar
soup48
soup48 is offline
Default RE: Riser bolt size?
I'm not sure without checking the bolt head size. If the Head size is 3/4" the bolt should be 1/2". I had added a set of risers from my brother's Lowrider to my "04 FXD.
Old 07-29-2006, 02:14 PM
murphdog's Avatar
murphdog
murphdog is offline
Harley risers are threaded 1/2-13. Some aftermarket ones are 1/2-20.
Old 07-29-2006, 02:26 PM
hd_sob's Avatar
hd_sob
hd_sob is offline
Don't forget, if ya go too tall, you might need longer cables, etc...
Old 07-29-2006, 03:40 PM
CHEESE's Avatar
CHEESE
CHEESE is offline
Oh yeah, I'm planning on changing them. So if I go with risers with the 1/2 - 20 bolts, I'll get new bolts, no sweat. Thanks for the responses.
92oldskoolxlh
03-12-2013 08:17 PM
DR. V-TWIN
06-05-2010 01:21 AM
Cornbread
04-22-2008 08:27 AM
RATROD HOG
11-10-2007 04:00 PM
Rauzer
04-13-2007 06:22 AM
Quick Reply: Riser bolt size?
