Tach install
Old 02-16-2010, 10:31 AM
trooper_355's Avatar
trooper_355
trooper_355 is offline
Default Tach install
What does it take to hook up a tach mounted on drag bars? 07 FXST
Old 02-16-2010, 07:35 PM
snip0721's Avatar
snip0721
snip0721 is offline
if memory serves me right, most are 4 wire units. hot, ground, light, and tach pick-up. you should find the tack pick-up (pink wire) taped back under the dash. steve
Old 02-16-2010, 07:45 PM
jd8181's Avatar
jd8181
jd8181 is offline
i hooked mine up last year. it was a peice of cake. yeah it was either 3 or 4 wires and all you have to do is match up colors. and there are different mounts fo the bars. i made a custom one because i wanted the tach under the bars rather than on top like all of harleys. i'll see if i can find a pic of mine
Old 02-16-2010, 07:50 PM
jd8181's Avatar
jd8181
jd8181 is offline
here's acouple of mine
Old 02-17-2010, 08:54 AM
rambler43's Avatar
rambler43
rambler43 is offline
Duct Tape LOL
Old 02-17-2010, 09:03 AM
wiseguy2day's Avatar
wiseguy2day
wiseguy2day is offline
JD, is that just a thin piece of steel sandwiched between the clamps?
Old 02-18-2010, 06:19 AM
jd8181's Avatar
jd8181
jd8181 is offline
yes it is. then i painted it black. i like it better than the big ones harley sells that put the tach above the bars
Sal C
08-28-2020 10:51 PM
604joe
Electrical/Lighting/Alarm
10-06-2016 03:02 AM
Herk1
11-26-2009 09:13 AM
russellabjr
06-21-2007 06:20 PM
Drtbag
02-27-2007 03:20 PM
Quick Reply: Tach install
