Sparkplugs- Accel v.s. HD v.s. NGK v.s. Champion
Old 02-11-2010, 06:12 PM
Ironkidzsled's Avatar
Ironkidzsled
Ironkidzsled is offline
Default Sparkplugs- Accel v.s. HD v.s. NGK v.s. Champion
Anyone give any advise on the best plugs for a 1000cc 74' xlch?
And out of these which is the better, Accel or HD?
Old 02-11-2010, 08:10 PM
piniongear's Avatar
piniongear
piniongear is offline
Any of the brands are going to be about the same.
Accel is proclaimed to be more plug than it actually is.
Harley sells plugs with their name on them, but you and I both know they do not manufacture spark plugs.
I like to just keep it simple and use Champions myself.
If you want to 'upgrade' on plugs, then buy some platinum plugs if you want to spend the money for them.
They will last longer than a regular plug, but then you can buy two plugs for the price of a single platinum. Maybe more than two.
pg
Old 02-11-2010, 08:38 PM
lightweight bob's Avatar
lightweight bob
lightweight bob is offline
Accel plugs are made by Denso (Toyota) while Champion makes for HD. Autolite plugs
seem very popular with Indy shops.
The latest techno plugs are iridium - go 100K miles in a water cooled car but don't
push'em that far in an air cooled engine.
If you use an ohm meter to check plug resistance you'll find Champions are higher than
the others resulting in a lower current spark.
Also, check your wires as the resistance goes up with age in carbon core designs
normally used / preferred because of reduced RFI / EMI properties. IMHO.
Old 02-11-2010, 08:40 PM
BLKBAGGER's Avatar
BLKBAGGER
BLKBAGGER is offline
I run Autolites and have been since I can remember.
Old 02-11-2010, 09:37 PM
IronMick's Avatar
IronMick
IronMick is offline
NGK here. Just because. No technical reasons. No one ever complains about them. They work for me.
Old 02-11-2010, 09:47 PM
Faast Ed's Avatar
Faast Ed
Faast Ed is offline
Most favorite NGK
Least favorite Champion (Had issue with the threads too many times)
No need for fancypants irridium plugs.
Old 02-11-2010, 11:21 PM
sepixlh's Avatar
sepixlh
sepixlh is offline
I have used "all brands" now I have used champion, if they foul they can be cleaned and used again. Most of other brands don't. There is slight differences between brands, HD labeled plugs go deeper into combustion camber.
Here picture first is HD then Nippondenso last Champion
Old 02-12-2010, 03:31 AM
shepdog's Avatar
shepdog
shepdog is offline
autolites in everything i own!
Old 02-12-2010, 07:06 AM
GA Ironhead's Avatar
GA Ironhead
GA Ironhead is offline
Originally Posted by Faast Ed
Most favorite NGK
+1. I run Autolite plugs. Never hear anything bad about NGK, however, Champions need to be gapped properly. Over the back fence is proper gap in my shop.
Old 02-12-2010, 08:17 AM
Ironkidzsled
Thanks for the responses. Yeah I'm currently running accel plugs but I've been a big fan of NGK for awhile now. I use NGK in my dirt bike (CR250 two stroke).. I like how the HD plugs reach deeper into the combustion chamber but if they aint got some fire that won't mean ****. If you are right about toyota being the manufacturer of them HD plugs? I'm prolly ganna have to try em! I DROVE THE **** outta my ol' 4x4 toyota sr5 pickup for the better part of 13 years and honestly you couldn't kill the damn thing! Ran like a top all the way up to the day I sold it (just last year @ 249,999 miles on it) only thing I ever replaced on it was the U joint & two front shocks. Wish I had never sold that truck...
Quick Reply: Sparkplugs- Accel v.s. HD v.s. NGK v.s. Champion
