Need Advice!! Thunderheader or V&H Pro-pipe High Output??
Old 02-10-2010, 09:21 AM
rlydan's Avatar
rlydan
rlydan is offline
Stage II
Default Need Advice!! Thunderheader or V&H Pro-pipe High Output??
Newbe here. So here I go...I have a 04 RG with 95" KB pistons, Complete head work, S&S570 w/Gear drive, Fueling lifters and oil pump, Rivera pro-clutch, Wild thing 57mm TB, Zipper AF, True dual Rineharts = 105hp -101tq. So Iam thinking of getting rid of the rineharts and installing a 2-into-1 thunderheader or the new Vance and Hines Pro pipe Hi-Output 2-into-1 pipe. I am also thinking of installing a Thundermax w/autotune setup. Any info would be helpful. Thanks
Old 02-10-2010, 09:26 AM
jackinthebox's Avatar
jackinthebox
jackinthebox is offline
Not an expert but I'm running thunderheader on my 107 gave me a nice boost over my duals. Heard the high output pipe is big built motors like 113's and above. I did see the high output one at a bike show and it did look nice. V&h does have good fit and finish
Old 02-10-2010, 09:29 AM
hog-doc's Avatar
hog-doc
hog-doc is offline
They both make great numbers and both have tier own sound. The HO Pro Pipe IS very nice. The Thunder Header is what it is as far as fit and chrome and crappy heat shields but they do work!
Old 03-31-2010, 05:44 PM
editbrain's Avatar
editbrain
editbrain is offline
I had the HO V & H pipe, and got an exhaust leak after one month. I have switched to a Thunderheader. The V&H is designed by a outer division of the company, and you will have to deal with them and not V&H if you have any issues. I know...
Old 03-31-2010, 05:45 PM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
Out of those two V&H. I still like the D&D fatcat better than both of them.
Old 03-31-2010, 06:23 PM
BLKBAGGER's Avatar
BLKBAGGER
BLKBAGGER is offline
I would go with the Thunder header if I had to choose between the two. Are those the only two pipes you are interested in?
Old 03-31-2010, 06:39 PM
FastBagger07's Avatar
FastBagger07
FastBagger07 is offline
If thats your two choices go with the Thunder Header.I have a ProPipe HO it is very very hot.They do not have heat shields for it either.I wrapped mine it did help greatly.But the pipe is for big blocks,being you only have a 95" i think the pipe would be overkill for your motor.
Old 03-31-2010, 06:40 PM
Indianspringsaz's Avatar
Indianspringsaz
Indianspringsaz is offline
Consider the D&D Fatcat. It is a high quality pipe with excellent workmanship.
Old 03-31-2010, 06:47 PM
roadgliderick's Avatar
roadgliderick
roadgliderick is offline
u cant beat the thunder header for performance
Old 03-31-2010, 07:56 PM
hog-doc's Avatar
hog-doc
hog-doc is offline
Actually you can, with either the Fat Cat, Road Rage or Pro Pipe HO.
I like Thunderheaders but they ARE NOT the best performers ANYMORE!
Quick Reply: Need Advice!! Thunderheader or V&H Pro-pipe High Output??
