1983 FXR Issues
Old 02-09-2010, 09:48 AM
83FXR_Marc's Avatar
83FXR_Marc
83FXR_Marc is offline
Default 1983 FXR Issues
My dad bought this 83 FXR brand new in 1983, I finally have the bike now, its been very well taken care of! I'm am having headlight issues, and some slow turn over issues. Ive blown 2 halogens in 6 months both of them were back to back. (pretty sure its cause i was using a reg car 9003 (H4), and was told to get Motorcycle lamp, so i did that and no issues after riding today. In the trouble shooting Ive been doing, found that the ground strap is breaking, so that ill fix tomorrow. Is that the root of the headlight problem im having, or was it the bulb?
Also there is a ground wire that goes from the starter relay and around the battery box to a screw that holds the rear brake reservoir, when i use my multimeter and ground the NEG side, and than touch the POS side to that ground i get a reading of like 1.2v(Vdc) but when i turn the key to the headlight position it jumps up higher and if i hit the HI-BEAM, even higher. Is this the signs of a short? if so(which I'm sure it is) is it the relay that's going bad?
Also when i turn it over for the first time of the day it wants to barley turn over on the first hit of the switch, 2nd time usually starts, battery is less than a year old and has been charged. When its warm there is no issues.
Old 02-09-2010, 09:56 AM
IronAss's Avatar
IronAss
IronAss is offline
Received 12,220 Likes on 4,770 Posts
Old 02-09-2010, 10:38 AM
Da Gumpmeister's Avatar
Da Gumpmeister
Da Gumpmeister is offline
Let me 'try' to addresss ( READ THAT -GUESS) your starting issue.
Harleys, because of their 'design', stop with ONE of them, coming up on compression. That said, when you go to 'start' it, tough sledding for the starter to 'roll it over' AND trying to fire, at same time. You let go of the button, hit it the 2nd time, Vrooooom. My 78 does it almost everytime it starts. The rest of the time, it will "FIRE" when you turn the key 'on'. "Pop". (This can be eliminated by jus' SLIGHTLY retarding the timing)
(Also, I have mine wired, first click of ign switch is Ign and brake kight, ONLY. Second click adds 'lights'. Mo' voltage for starter and ign, that way.)
This is PESHALLY troubling, when you have electronic ign, and have it set to "kick" vs "electric"
In the "electric" mode, it will turn one full revolution BEFORE the ign will 'fire'. I believe you are schmott enough, to figure out why THIS is BAD, when you are 'kicking' it to life.
Also, the Prestolite and Hitachi staters, were only .7kw. Good enough for 'stockers', USUALLY. But weak in the poop IF you've done any headwork, cubic "s, compression ^, etc.
Least expensive 1.4kw that I've found, is the Ultima .
There are Prestolite and Hitachi 1.4s, but they are just as expensive as Spyke and ALL-*****. But they work good for the guy who wants to keep the 'original' looks.
You sorta 'lost me' on your electrical testing, there. Not zacklee sure why you have that ground running to the brake res. Trying in my head, to picture what you have, and what you were reading, there. ?????????
I run PIAA Xtreme White H-4's, 110/100w @ 60/55w in ALL our scoots (DEER !!!!!!!!!!!!!!!!!) Thusly, I run them via secondary relays, to handle the 'load'. The dimmer switch just flips the relays, NOT the lights themselves. The 'current' draw, will fry the dimmer switch, and the small handlebar wires.
I eat at least one or 2 bulbs a season (HARDTAIL - vibration/shock)
Check your ground for the headlight bulb, itself. I redo mine, IF NECESSARY, so they are grounded right at or very near, the headlight bucket/triple trees.
IF you don't have any in your box, grab some "Di-electric" grease at NAPA, Checker's, what have you. Use it on EVERY electrical connection you fiddle with. Batt cable, plug ins, bulb bases, ANYTHING. Eventually, you will have the WHOLE scoot done. Can really save you those 'qwirky' electrical/corrosion probs. BUT, JMFUO, as "ooze-all".
Gonna have to 'grind' on that testing thang, you got going on, tho. Ya lost me, there.
Dammd, that HOME GROWN is way betta than I thought !!!!!!!
Old 02-09-2010, 11:10 AM
piasspj's Avatar
piasspj
piasspj is offline
Not sure I understand exactly what your touching with you leads but it sounds like you have power going to something that isn't well grounded.
Could be the broken strap you mention. Could also be corrosion on mounting bolts, terminals or even inside wires.
83FXR_Marc
08-28-2020 06:29 PM
0maha
EVO
03-20-2015 01:56 PM
dirtbag1
EVO
01-10-2013 09:40 AM
Tactical111
EVO
08-27-2010 11:40 AM
jptaylor2
06-13-2009 06:36 AM
Quick Reply: 1983 FXR Issues
