Biggest front tire on stock 06 FXDWG wheel
Old 02-08-2010, 07:06 PM
C&S 75's Avatar
C&S 75
C&S 75 is offline
Default Biggest front tire on stock 06 FXDWG wheel
It may seem a little stupid but I am having a difficult time getting info on the biggest Metzeler ME 880 Marathon tire that will mount on my stock wheel. I asked my local Dealer, but you all can guess what they told me. I already knew what is recommended!
I have a 2006 Dyna Wide Glide. It came with a MH90-21 Dunlop. I'm not sure what my rim size is. I feel every bump in the road with such a small tire. It also does not handle the freeway rain grooves very well. I have plenty of room. My fender must be at least an 1 1/2 above the tire.
I have a Marathon 880 on the rear. Metzeler only makes a couple of 21" an ME 880 Marathons. They have MH90 - 21 M/C 54HTL, 90/90 - 21 M/C 54H. It seems the next biggest tire is a 120/70 - 21 M/C 62V.
Has anyone ever used a 120/70 21 on a stock Wide Glide rim? Would it work? I would hate to have the tire roll off the rim in a hard turn! That would kinda suck!!
Any advise would be appreciated.
Old 02-08-2010, 07:08 PM
C&S 75's Avatar
C&S 75
C&S 75 is offline
Thanks.
Old 02-09-2010, 08:03 PM
murphdog's Avatar
murphdog
murphdog is offline
Your rim is 2.15" wide and the 90/90 is the biggest tire you should put on it. I've heard of a couple guys that put a 120 on the stock rim, but I wouldn't try it myself. Metzeler says 3" minimum for the 120. I had a 90/90 Metzeler on my '03 Wide Glide and it was way better than the stock Dunlop, it didn't follow the grooves hardly at all.
Old 02-23-2010, 01:34 PM
Pickard USA's Avatar
Pickard USA
Pickard USA is offline
Former Sponsor
I would definitely not recommend putting a 120 on your 2.15 wide rim. The 90/90/21 is the widest you should go, any wider and you are taking a risk. The 120 is designed for a wider (3.25) wheel and squeezing it on a smaller wheel could be hazardous. Just my 2 cents.
MrHog
02-25-2022 10:01 AM
Keith_71
05-14-2012 08:31 PM
chrisamberely
03-28-2012 03:50 PM
jeeperbrad
09-09-2010 07:48 AM
VenturaChop
12-01-2007 11:22 PM
Quick Reply: Biggest front tire on stock 06 FXDWG wheel
