Six Speed
Old 02-03-2010, 06:59 PM
WIZARD's Avatar
WIZARD
WIZARD is offline
Default Six Speed
Hi all,
I am thinking about modifying the transmission of my 2001 Roadking from a 5 -speed to a six speed. Two questions about that...
1. I saw a Dyna six speed gear set for sale. Will it fit in my transmission case? I think it will, but i'm not sure. Could anyone help me out.
2. Another reason I have opened the transmission is oil leakage. But strangely it's not the seal or gaskets, it's leaking through the main transmission shaft. The part where the clutch pin is coming out. What could be wrong?
I hope some can help. Thanks in advance.
Regards,
Michael.
Old 02-03-2010, 08:18 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,499 Likes on 4,612 Posts
Need more information on the Dyna, what year, is it an original 6 speed from the factory or aftermarket unit.
The transmission mainshaft is hollow, the clutch actuator pushrod passes through it.
Oil usually does not pass through the shaft because it is higher than the level of the oil.
Even if oil were to pass through the shaft, it would leak into the primary, not overboard.
Old 02-03-2010, 09:02 PM
arollam's Avatar
arollam
arollam is offline
Default same question
I actually have the same (first) question about a 2004 RKC. Can I replace the 5 speed with a six speed?
Old 02-03-2010, 10:10 PM
adriyanna62's Avatar
adriyanna62
adriyanna62 is offline
Stage II
Hi all,
I am thinking about modifying the transmission of my 2001 Road king from a 5 to a six speed. Two questions about that................
_____________________________________________
Hotel London
Old 02-03-2010, 10:18 PM
hog-doc's Avatar
hog-doc
hog-doc is offline
Originally Posted by WIZARD
Hi all,
Regards,
Michael.
1: NO it will not fit, the factory 6 speeds use a completely different case.
2: When you say its leaking out of the main shaft, the only place it can go is to the primary, that wouldnt allow it to leak outside the tranny, so Iam not sure what you mean by its leaking!
Old 02-03-2010, 10:19 PM
hog-doc's Avatar
hog-doc
hog-doc is offline
You can with either an SE or Baker 6 speed!
Old 02-04-2010, 03:08 AM
WIZARD's Avatar
WIZARD
WIZARD is offline
Oh, yes, I forgot to mention I have a primary beltdrive. Thats is why I can see the leakage. It is coming through the (dry) clutch. When I opened it up, I found it came from within the main shaft.
Old 02-04-2010, 04:52 AM
jkoch09ultra's Avatar
jkoch09ultra
jkoch09ultra is offline
Get in touch with Baker. I visited them at their tent in Daytona looking to do the same on my 06 Ultra. They have gear sets that fit your existing case or a complete unit for most Harleys. If you have the money they have the solution. I did not know that they had so many options. I eventially went with a trade up to a 09 UC. If you are going to Daytona they are usually at Rosesmyers.(sp)
fxhawg85
02-19-2018 07:30 AM
shankman
Shovelhead
08-23-2016 08:43 AM
tony a
06-10-2013 03:12 AM
W4MAC
Shovelhead
04-25-2013 10:33 AM
fasteddie
05-09-2008 11:30 PM
Quick Reply: Six Speed
