110 ci HP
Old 07-23-2006, 08:05 PM
eddybo69's Avatar
eddybo69
eddybo69 is offline
Default 110 ci HP
I noticed that the 110 cid engine is making 115 ftlbs torque...has anyone found or estimated HP?
Old 07-24-2006, 08:31 PM
nidan's Avatar
nidan
nidan is offline
Default RE: 110 ci HP
HP = (Torque X RPM) /5252 so crank hp should be in the mid to high 90's depending on the torque curve.
Rear wheel torque and hp should be around 104lbs ft /low 80HP range.. however with cams and some headwork ...
Old 07-24-2006, 09:27 PM
eddybo69's Avatar
eddybo69
eddybo69 is offline
Thanks, I couldnt remember a formula for that. I cant wait to see what the seat of the pants-o-meter says about it.
Old 07-25-2006, 03:26 PM
1941ratrod's Avatar
1941ratrod
1941ratrod is offline
I had Revolution Performance http://www.revperf.com/default.aspx build me a 114 that puts out 138hp and 140flbs of torqe check them out its way worth the money.
galaxyfe
Engine Mechanical Topics
08-22-2015 07:33 PM
banjoplayer2
11-08-2013 02:38 PM
dan conner
12-12-2011 07:55 AM
Vector
08-10-2007 03:14 PM
Fred00
04-18-2007 11:54 AM
Quick Reply: 110 ci HP
