Recalibrate the ECM after installing the SE Air Filter kit
Old 01-26-2010, 10:11 AM
boston138's Avatar
boston138
boston138 is offline
Default Recalibrate the ECM after installing the SE Air Filter kit
I was told at the Harley Shop that I would not have to recalibrate the ECM if I only installed the SE Stage 1 Air Filter kit. After buying it, I was suprised to read in the instructions that Failure to properly recalibrate the ECM can result in severe engine damage. Who should I believe?
Old 01-26-2010, 10:15 AM
mongomark's Avatar
mongomark
mongomark is offline
What's your combo?
Pardner's Avatar
Pardner
Pardner is offline
Well, opinions vary ... having said that, general rule is, if you change A/C AND pipes, you need to remap. If you just change one of them you don't.
Old 01-26-2010, 10:29 AM
boston138's Avatar
boston138
My bike is 08 Ultra Classic and the only change is the SE Air Filter
Old 01-26-2010, 10:41 AM
im's Avatar
im
im is offline
The bikes run lean from factory..increase the air going in or out makes bike leaner.
Read spark plugs for non-specific idea of lean..
I would consider something to add more fuel to bike.
Many options and prices.
Old 01-26-2010, 11:38 AM
troop's Avatar
troop
troop is offline
I think the MOCO recommends a flash with intake. Much more air coming in....
Old 01-26-2010, 12:11 PM
RK4ME's Avatar
RK4ME
RK4ME is offline
Received 2,211 Likes on 1,380 Posts
That's what I did with my '04 RK, and it still ran borderline lean. A PC V w/canned map from Fuel moto solved that - no more spitting back through the intake off-idle. The engine runs cooler and stronger, and even sounds better. Maybe the closed loop EFI on the newer bikes will compensate for the AC without a flash?
Old 01-26-2010, 01:37 PM
Flying Horse's Avatar
Flying Horse
Flying Horse is offline
The dealer told me to flash the exhaust upgrade but that the intake doesn't require a flash. That's what I did and haven't had any issues over the past couple years.
flhrbill's Avatar
flhrbill
flhrbill is offline
I had the SE air filter installed and was told I needed the remapp. Once I remapped I installed SE slip-ons. The performance is much better.
Old 01-26-2010, 06:57 PM
Ronp42's Avatar
Ronp42
Ronp42 is offline
Account Retired
I was told the same thing by my Dealer service guy. But I was also told there was not much good in doing it without changing the mufflers and doing the ECM download . I did the stage1 w/K&N AF. I wasn't satisfied with the results, So I bought a set of FuelMoto's Jackpot's. I took the bike back and had the service guy check the download to make sure everything was alright. He said he richened it up a little. I like the performance better now. Better throttle response. I might add the PC-V from FuelMoto when hot weather get's here. If I had it to do over, I would get the package from Jamie @ FuelMoto. Great price and service, Those Dyna Tuned Jackpot's are IMO the best sounding and best looking Muffler's out there.
Buggz
05-24-2011 08:01 PM
jackinthebox
09-29-2010 09:48 PM
tlb
08-24-2007 05:23 PM
Abnmarine
01-30-2007 09:07 PM
wnogood
12-03-2006 03:18 PM
Quick Reply: Recalibrate the ECM after installing the SE Air Filter kit
