Progressive "drop in" lowering kit
Old 01-25-2010, 04:47 PM
JFonzka's Avatar
JFonzka
JFonzka is offline
Default Progressive "drop in" lowering kit
For those of you with the progressive drop in lowering kit, how much of the spacer did you cut off and how much of a drop did it give you? Im trying to get some kind of an idea before i tackle this task. Thanks Justin
Heres a pic for clicks
Old 01-25-2010, 05:02 PM
boosteddelslow's Avatar
boosteddelslow
boosteddelslow is offline
I didnt cut the spacers at all as per the instructions for a fxst. I got about a 1.25-1.375 drop. I was a little dissapointed because I wanted 2 inches. But I was to lazy to take it all apart again. So what are they 4.5. I think that if you cut them to 4 that would be pretty good. The spacers are 3/4 inch pvc so it is cheap to experiment. Just a pain in the a$$. I was going to just remove the fork caps and loosen the pinch bolts. Then you can slide the whole front end down enough to get the spacers out.
Old 01-25-2010, 08:51 PM
Bugsplat's Avatar
Bugsplat
Bugsplat is offline
I cut an inch off the spacer as per the instructions for an 08' Deluxe and got just over an inch. To get the full drop you cut the spacer down to the minimum recommended length - that is what the progressive tech person told me.
Old 01-25-2010, 10:28 PM
gforrest2's Avatar
gforrest2
gforrest2 is offline
JFonzka and all. Sorry for getting off topic but your bike is sharp! I've seen the tan seats (unmounted) and thought ugh, but the other posters are right. A tan seat on a black bike is bada$$.
Old 01-25-2010, 11:06 PM
dkyork's Avatar
dkyork
dkyork is offline
Yep,
I left my pvc at 4.5 and only got about 1.25" drop as well. I did fill it with 12.5 ounces of fork oil though per the guide, but that amount should be based off the original stock height. I'm thinking about draining an ounce out to see if it makes a difference, but right now I have tons of other things on my bike to fix and get working. Let us know if you can get the two full inches.
regards,
Dale
Old 02-02-2010, 01:44 AM
OUTLAW1969's Avatar
OUTLAW1969
OUTLAW1969 is offline
I am about to do this too, and am interested in how much to trim off for an '98 FXSTC. The guide states to leave the PVC the same length, but I also want the 2 inch drop. I think there is another post on here where the guy makes reference to how much he cut off to get the desired result. I am off to the "SEARCH" function....
Old 02-02-2010, 05:52 AM
boosteddelslow
I would guess that you would trim off an additional 3/4" of an inch for a full 2" drop. I think the instructions tell you a max amount to trim off but I forget what it is. I am pretty sure it is less than 3/4" LOL. But you could try it. I would guess the reason they tell you not to trim off to much is that the springs dont have enough preload. Just a guess though.
Old 02-02-2010, 06:57 AM
ElSupremo's Avatar
ElSupremo
ElSupremo is offline
My spacers are 2.5" and I'm dropped about 2.5" from stock.
Old 02-02-2010, 08:36 AM
Rockyriver's Avatar
Rockyriver
Rockyriver is offline
Here is a copy of the instructions below. These lengths are for 2" of drop (but vary's per bike).
On the left hand side of the instructions in the Chart PVC spacer length, it tells you to cut spacer to a length of 4.50 for a 2" drop on a FXSTB.
I cut my spacer to 2 3/4 for a for a 2 1/4 drop (I own a FLSTN). I wish I would of left it for only a recommended 2" drop. If you get it too low its hard to get a jack under the bike. All bikes vary however, you may get 1.5 inch drop and another bike may get a 2 inch drop, is my understanding. If you go with the 4.0 instead of the recommended 4.5 inch spacer and check your height and then decide if you want lower or higher (PVC is cheap at the store). I think its pretty easy to take a FXSTB back down and adjust height, that is easy compared to my bike.
Old 02-03-2010, 03:38 AM
OUTLAW1969's Avatar
OUTLAW1969
4 inches it is, then. THANKS GUYS! I will check back in next week with the results, when I am off work again, and can do the install.
Quick Reply: Progressive "drop in" lowering kit
