DYNA Oil Coolers
Old 01-20-2010, 04:15 PM
BlockHead96's Avatar
BlockHead96
BlockHead96 is offline
Default DYNA Oil Coolers
What are you running? I know it's all opinion, but curious as to which may be better than others. I think this will be the last winter mod I do before riding season comes around. Brand, ease of install, quality, appearence, etc etc...
Old 01-20-2010, 04:21 PM
Cornhusker's Avatar
Cornhusker
Cornhusker is offline
I haven't ran an oil cooler in years. Haven't had any problem. I change the fluids/filters regularly and so far, it seems to work.
Old 01-20-2010, 04:54 PM
Lennyone's Avatar
Lennyone
Lennyone is offline
I purchased Jagg's Number 4600 Offset Oil Filter Adapters which install between the engine and oil filter. Billet aluminum construction. I have the front mount oil cooler which mounts to the front two bolts of the engine mount. H D does not make a cooler for my 2005 FXDX any more. I believe I need this because my oil smells like it is burned. The head temperature must be heating the oil very hot. I believe the oil cooler plus my air cooling fan should help put a stop this. I would like to run cooling fan for about 5 minute after I shut motor off to cool the heads just like my Buell. I don't trust my battery. even with the compression release's.
Old 01-20-2010, 04:59 PM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
I don't have one on my bike, but if I did it would be a Jagg.
Old 01-20-2010, 05:18 PM
dope_man_21's Avatar
dope_man_21
dope_man_21 is offline
I have the Milwaukee twins dual cool II, but have yet to install it.
Old 01-20-2010, 06:13 PM
domenicp7's Avatar
domenicp7
domenicp7 is offline
Premium HD Oil Cooler here. The thermostat activates at 185°F (85°C) works well for me with engine mods I have done and the Texas summers can be a little warm.
Old 01-20-2010, 06:29 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
seniorsuperglideE8 is offline
Received 4,312 Likes on 2,358 Posts
Jagg oil coolers on both bikes. The cooler is mounted on the left down tube. There is an adapter between the oil filter and o/f mount. The 02 has been on for about 7 years and the 05's about 4 1/2 years.
Old 01-20-2010, 07:34 PM
Far 3ast's Avatar
Far 3ast
Far 3ast is offline
I have the HD Premium on my '00 FXDX....works well, doesn't come on unless needed due to the built in thermostat, so no need to bypass or cover during winter.
I looked at Jagg but decided to go with the H-D part becuase everything you need is in the box. With Jagg you have to figure out what all is needed and order everything separately. The price wasn't much difference, and I didn't feel like doing all the research needed for buying the Jagg.
Old 01-20-2010, 08:08 PM
WS6 Formula's Avatar
WS6 Formula
WS6 Formula is offline
I found a discontinued Harley Davidson oil cooler that is made by Jagg on eBay. More info in the below link
https://www.hdforums.com/forum/dyna-...il-cooler.html
Old 01-20-2010, 09:52 PM
BlockHead96
Unfortunately, those types don't work with bikes with the EVAP Canister!
Quick Reply: DYNA Oil Coolers
