Replacing Plug Wires
Old 01-18-2010, 09:58 AM
aviscomi's Avatar
aviscomi
aviscomi is online now
Default Replacing Plug Wires
Let me start by saying that I don't have the service manual...yet (just ordered it). I am about to replace the Spark Plug wires on my 2005 Ultra and notice that the coil is "tucked" under the tank; my question is...do I have to remove the tank to get to it?
Old 01-18-2010, 10:13 AM
hog-doc's Avatar
hog-doc
hog-doc is offline
Remove the front bolts and loosen the rear, just lift it up, no need to remove.
Old 01-18-2010, 10:16 AM
boulderbean's Avatar
boulderbean
boulderbean is offline
Default I am looking into this also
I have not yet done this, but I am looking into if on a 2005 Road King.
From what I have read you can lift the tank enough to get to the coil and to feed the wires under that tank.
To lift the tank you do not need to remove the crossover fuel line.
From what I remember, on the Road King, you remove the front mount and rear mounting bolts and then lift the tank gently until the crossover is up against the frame, block up the tank with a piece of 2 by 4.
You can also lift and block up the rear a bit to help in passing wires under the tank.
bb
Old 01-18-2010, 10:26 AM
tombeving's Avatar
tombeving
tombeving is offline
I have an 05 Ultra also, and from what I can see with a needle nose pliers you should be able to install the new wires without lifting the tank.
Old 01-18-2010, 06:12 PM
jag1886's Avatar
jag1886
jag1886 is offline
What he said.
Old 01-18-2010, 06:37 PM
Sancho's Avatar
Sancho
Sancho is offline
I just installed some SE 10mm on my '10 RGC. My coil is behind the engine so I can't help, but I noticed on the box the wires came in a sticker saying it could effect my warranty. I farted on my seat the othr day. I wonder if that will have any effect on my warranty?
Old 01-18-2010, 06:54 PM
RickDeVon's Avatar
RickDeVon
RickDeVon is offline
Not if it is Dealer installed.......Now what is up with that..........
Old 01-18-2010, 06:57 PM
aviscomi's Avatar
aviscomi
I just installed the SE wires & plugs, thanks for all your help. BTW, my Nightrain scores a point against the Ultra for coil location.
Old 01-18-2010, 07:42 PM
pled55's Avatar
pled55
pled55 is offline
don't know about effecting the warranty.but the fart is probably normal.better check with the dealer on that
creep1
04-15-2015 01:05 PM
skydweller97
10-15-2014 06:57 PM
iambill
04-06-2010 09:24 PM
Taddeoeg
02-21-2010 08:00 PM
kommandokenny
11-10-2006 11:04 AM
Quick Reply: Replacing Plug Wires
