radio beeps electraglide
Old 01-07-2010, 06:59 PM
tncooks's Avatar
tncooks
tncooks is offline
1st Gear
Question radio beeps electraglide
2009 electraglide, just installed new speakers, radio, & antenna works but radio beeps 3 times cutting radio off while beeping then radio comes back on does this every 10 seconds, also radio says on screen not calibrated. anyone know how to solve this?
Old 01-07-2010, 07:16 PM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
A Harley dealer needs to hook-up the Digital Technician to "calibrate" the radio.
hog-doc's Avatar
hog-doc
hog-doc is offline
It needs the region code set. Your dealer has to do it with the Digital Tech computer.
Old 01-07-2010, 07:17 PM
tncooks's Avatar
tncooks
tncooks is offline
1st Gear
is there anyway to aviod going to the dealership?
Old 01-07-2010, 07:25 PM
Potato_Potato's Avatar
Potato_Potato
Potato_Potato is offline
Don't know for sure but I would try pulling the Maxi fuse for a good 10 minutes or even overnight. Also I think I remember reading a procedure for rebooting the radio by holding in certain buttons as you power it up. Check your Owner's or Service manual.
The thought here is that there is a glitch in the system and rebooting or disabling the power to it long enough for it to reset itself might fix it. Kinda like when your computer is acting up and you reboot.
Old 01-07-2010, 07:36 PM
D2R's Avatar
D2R
D2R is offline
Which radio? I went with the Biketronics Retro Radio and a Sony head unit.No beep or messages.
Old 01-07-2010, 08:11 PM
Iron Cross Audio's Avatar
Iron Cross Audio
Iron Cross Audio is offline
Former Sponsor
Dealer or Iron Cross Audio are probably your only options.
Old 01-07-2010, 08:43 PM
acchd's Avatar
acchd
acchd is offline
Is this a Sony headunit? They have a annoying beep like that as a reminder to remove the faceplate.
Old 01-08-2010, 09:40 AM
hog-doc's Avatar
hog-doc
hog-doc is offline
Pulling the fuse WILL NOT fix it. It is a setting that HAS to be manually confirmed with the computer so that the radio knows what part of the world it is in.
Old 01-08-2010, 09:52 AM
FLHTCU Owner's Avatar
FLHTCU Owner
FLHTCU Owner is offline
Maybe it's a 70's radio and wants you to play the Tony Orlando song "Knock 3 Times" ? Sorry, had to say it.
Quick Reply: radio beeps electraglide
