Issues with 2010 Street Glide?
Old 01-03-2010, 06:57 PM
Rando's Avatar
Rando
Rando is offline
Default Issues with 2010 Street Glide?
Workin' on moving from my '02 Fatboy to a Glide... either an '09 or '10 as I want to take advantage of the frame improvements.
I do like the looks of the 2010 - I'm a 2 into 1 exhaust fan, and I like the looks of the rear fender w/out the external tail light. Thing is I've heard some negative comments about the catalytics in the exhaust and something about the 02 sensors. How big an issue(s) are these - really?
I know that if I pull the trigger on a new(er) bike, there won't be much ching left to make a bunch of changes for awhile, so I'd better be happy with what I buy. I think that every model year has it's "issues" - real or imagined...
If I were to find a new or low mileage '09 I would definately go to a 2 into 1 pipe anyway.
So, whaddya guys & gals think - are the issues with the 2010's something that'll have to be dealt with / cause problems down the road? I do like the looks of 'em...
thanks in advance,
Rando
Old 01-03-2010, 07:05 PM
woosh's Avatar
woosh
woosh is offline
Don't think you could go wrong with either, I'm not a 2 into 1 exhaust fan. I just don't think it looks right without 2 mufflers. JMHO
Old 01-03-2010, 07:31 PM
BeeRAD56's Avatar
BeeRAD56
BeeRAD56 is offline
My '10 SG is one of the best handling bikes I've ever ridden and the fit and finish is excellent also. As a 50 state EPA compliant set up it runs lean and hot. Immediate mods will be to exhaust (to get rid of the cat and get more of the traditional sound), high flow intake, and EFI, mainly to get the temps. down. Otherwise I'm very happy with it and not much I plan to change.
DwayneH (03-26-2021)
Old 01-03-2010, 07:35 PM
VTwin-Goodies's Avatar
VTwin-Goodies
VTwin-Goodies is offline
Sponsor
Received 1,935 Likes on 1,919 Posts
Plan on getting a full exhaust to help cure the hot/lean condition along with a tuner and air filter setup. Aside from that you will be good to go.
__________________
Old 01-04-2010, 05:08 PM
luc.who's Avatar
luc.who
luc.who is offline
Default Can't go wrong with either year
What color do you want? I really wanted a RB SG, but was not willing to pay more for an 09 than a 2010. What ever you choose, both years are good. Get Cruise, ABS and security.
Old 01-04-2010, 05:16 PM
Eric Moore's Avatar
Eric Moore
Eric Moore is offline
the 2010 has the 18 frt wheel & clean looking rear fender...
Old 01-04-2010, 09:38 PM
Rando's Avatar
Rando
Rando is offline
If'n I go with the 2010 and swap out the exhaust, what's involved in pulling the cats - are they located in the exhaust itself or in the heads where the exhaust mounts?
Never thought I'd consider any other color than black, but (gulp) I do like the looks of the Scarlet Red...
How much hotter do the '10's tend to run with the cats?
Old 01-04-2010, 11:54 PM
DTTJGlide's Avatar
DTTJGlide
DTTJGlide is offline
The cats are in the head pipe, you can drill them out, you can send them out to Fulsac & they will cut them out or you can cut them out yourself, do a search as all have been discussed here. Otherwise you can just go with a full exhaust & keep the stock set-up should you ever have to pass a smog test. All the newer bikes run hot because they run so lean, you just need to free up the air going in & the exhaust going out, then you need a good tune to richen them up. Both years are good & you'll have to do most of the same things to both to make them better.
gtrplyr
05-06-2012 09:08 PM
Scorpion01
09-08-2010 09:58 PM
Coastiejosh
01-24-2010 07:59 PM
Road_King_Rob_78
The General Motorcycle Forum
11-08-2009 07:35 AM
vinnieee
09-18-2009 08:52 PM
Quick Reply: Issues with 2010 Street Glide?
