Fuel Octane for 2007 Sportster
Old 12-16-2009, 11:35 PM
cakep's Avatar
cakep
cakep is offline
Default Fuel Octane for 2007 Sportster
Hi,
What grade of fuel do you recommend for a 2007 Sportster Custom? should I use the highest (92)?
Thanks.
C
Old 12-17-2009, 01:22 AM
Lincoln33's Avatar
Lincoln33
Lincoln33 is offline
I always use the highest grade possible. The couple of times I've been forced to use a lower grade (gassing up in a small town) I could hear pinging.
Old 12-17-2009, 06:39 AM
kahaone's Avatar
kahaone
kahaone is offline
Old 12-17-2009, 09:01 AM
fox4's Avatar
fox4
fox4 is offline
I'd go with what the owners manual says and go with 91 or better.
Old 12-17-2009, 10:29 AM
SportyPig's Avatar
SportyPig
SportyPig is offline
You didn't mention the engine size.....makes a difference.
Old 12-17-2009, 10:39 AM
cHarley's Avatar
cHarley
cHarley is offline
Harley specs call for:
All EFI (07 & up) Sportys = 91+ octane
For 06 and earlier Sportys, 883 = 87 octane - 1200's = 91+ octane.
This is using the USA (R+M)/2 octane rating system.
Old 12-17-2009, 10:42 AM
SportyPig's Avatar
SportyPig
That's curious. Why would the change to EFI in 2007 cause a need for higher octane fuel on the 883 models? As far as I know, the engine, compression ratios etc etc remained the same.
Old 12-17-2009, 10:51 AM
XL50#674's Avatar
XL50#674
XL50#674 is offline
I run 92-93 even 94 if I can find it. I never go below 92 on my bikes.
Old 12-17-2009, 11:05 AM
cHarley's Avatar
cHarley
cHarley is offline
It has to do with with a change in ignition timing on EFI motors to provide a better fuel burn. I "assume" that is all related to HD going to EFI to provide a cleaner burn to meet the EPA crap.
Old 12-17-2009, 02:51 PM
SportyPig's Avatar
SportyPig
okiee dokie. Glad I have a carb. EFI will be a much better mouse trap, once they finally figure out how to tune and adjust the damn things.
Once I complete my next upgrade, I'll certainly be running higher octane. But for now, 87 works just as good as 93.
Quick Reply: Fuel Octane for 2007 Sportster
