loose ignition switch
Old 12-16-2009, 04:50 PM
midnitewolf's Avatar
midnitewolf
midnitewolf is offline
Default loose ignition switch
I have an 08 Street Bob and I noticed the switch is loose
in the frame . I twisted the outside trim ring with my fingers to snug it up some . What do I have to do to tighten it up?
Old 12-16-2009, 08:09 PM
jarhead45's Avatar
jarhead45
jarhead45 is offline
harley special tool. get it done ....my bike started cutting out. Complete loss of power. I thought it was the loose swich, had to replace the ignition to solve the problem. You may or may not have a similar problem
Old 12-16-2009, 08:42 PM
maddghost's Avatar
maddghost
maddghost is offline
Although my switch is on the tank,i still have the fork lock in that position. There is a decal covering two holes on the piece itself. peel the decal off carefully then use a pair of long nose pliers sticking one prong into each hole and turn the thing till it's nice and tight.I stuck My decal back on and so far it stayed ,this was back in june.
Old 12-16-2009, 09:23 PM
cactusred's Avatar
cactusred
cactusred is offline
Hey bro, I just had my ignition switch out not 3 weeks ago it was sticking, and after the last year of spraying all my lube/graphite/sprays in there, I said F*^% it, it's coming out and getting it's act together, pumped the tumbler full of grease, now she's like new.Anyway, Like previous poster said, peel that round decal off and you'll see a collar with half dozen holes, take a screw driver or punch and a hammer and some little taps and you'll rotate the collar around to tighten it. However I destroyed my decal getting it off, I suppose I should of got my heat gun out, cooked the decal a little to soften the glue then it would of sprang off the fork, but no. It's okay, I bought a new one from the dealer for about a buck.
Old 12-17-2009, 02:35 AM
midnitewolf
Thanks , after I thought about it for a minute I figured out the decal
pops off and from there I was good to go except the it took me another minute to figure out that it backs out to tighten the switch
Old 12-17-2009, 05:06 AM
maddghost's Avatar
maddghost
LOL same here! mine almost fell out when .....DoH! Glad you got it!
wmarketst
07-26-2015 10:14 AM
bearammus
03-06-2014 08:08 PM
burgies08ultra
02-23-2014 09:27 PM
Gliden
01-02-2012 04:23 PM
Badbagger
03-21-2010 07:51 PM
Quick Reply: loose ignition switch
