Vibration problems with Dyna Super Glide.
Old 12-06-2009, 08:57 PM
Rydertp's Avatar
Rydertp
Rydertp is offline
Stage IV
Question Vibration problems with Dyna Super Glide.
Hi,
I have a 2009 Dyna Super Glide with 2600 miles. It was smooth up until a few hundred miles ago. Now there are vibrations which are felt through the foot pegs, seat and handle bars. The vibration in the foot pegs is low frequency during acceleration then becomes steady at cruising speed. The worst of the vibration is through the pegs and seat and to a lesser degree at the handle bars. I've had the bike to the dealer and they said the upper motor mounts were lose. They tightened them and said the problem was reduced but not entirely gone. Also the fuel milage has decreased by 4 to 5 miles per gallon. Any ideas.
Old 12-06-2009, 09:02 PM
ackman1968's Avatar
ackman1968
ackman1968 is offline
Have them check the tires for balance and also look at the steering head bearings.
Phrogman's Avatar
Phrogman
Phrogman is offline
Check your front motor mount. I know they used to have problems with those deteriorating, especially if oil is spilled on the bearing and not completely cleaned off. Oddly enough, any petroleum based product doesn't fare well when petroleum products are spilled on them.
Also, some guys on this site have found a problem with a preload in the motor/mount setup. For some reason the motor isn't properly centered in the frame at the factory and they just crank the bolts down on the front motor mount to pull it into position. This creates a preload and can eventually pull the motor mount apart causing increased vibration once the mount completely fails.
There is a centering procedure in the manual, plus I think a few people on here have detailed it a time or two.
Old 12-08-2009, 11:30 PM
archergodwin's Avatar
archergodwin
archergodwin is offline
The vehicle alignment procedure outlined in the service manual, and removing the preload from the front motor mount, removed a serious amount of vibration from the bike. Also helped the handling quite bit as well.
Old 12-09-2009, 07:07 AM
Rydertp's Avatar
Rydertp
Rydertp is offline
Stage IV
Thanks for the tips, I have an appointment with the dealer this morning and I will suggest they check these areas. It will be nice to have a smooth riding bike again.
Old 12-10-2009, 12:13 PM
coconl's Avatar
coconl
coconl is offline
Thumbs up vibration
Sorry about this but in V Twin forum there is a thread how to fix the vibration. It has to do with the front motor mount. Loosen the front mount and there will be a space between the mount and the motor. Get a spacer the same width , drill the holes same as mount and insert, it seems to take away most of the vibration on all DYNA s . I don't know how to do a link or I would have.
Old 12-10-2009, 12:58 PM
rcaddell's Avatar
rcaddell
rcaddell is offline
Tons of threads on this with the very same fix on this forum as well coconl
Old 12-11-2009, 12:13 PM
Rydertp's Avatar
Rydertp
Rydertp is offline
Stage IV
Thanks for all the help. I have taken care of the problem. Great to have all this information available and people willing to help.
Old 12-11-2009, 12:27 PM
mxdad32's Avatar
mxdad32
mxdad32 is offline
Well, what was it???
Old 12-11-2009, 12:28 PM
Tnbrit's Avatar
Tnbrit
Tnbrit is offline
What did you find?
Quick Reply: Vibration problems with Dyna Super Glide.
