Sponsored by: Jekill and Hyde
Bench Test a Oil Pump?
Old 12-02-2009, 01:01 PM
Anezangl's Avatar
Anezangl
Anezangl is offline
Question Bench Test a Oil Pump?
Can ya and how do ya?
Old 12-02-2009, 01:47 PM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
to find out what?weather its good,pressure at different RPM`s or what?
kirby
Old 12-02-2009, 02:08 PM
djl's Avatar
djl
djl is offline
Received 2,017 Likes on 1,491 Posts
Why??
Old 12-02-2009, 02:36 PM
TXCHOP's Avatar
TXCHOP
TXCHOP is offline
Just make sure its assembled correctly. I saw your thread with no oil pressure...Are your lifters clackin away?
Old 12-02-2009, 03:02 PM
prodrag1320
tried to go back thru your posts,too much of a pain in the ***,whats the problem from the start again
kirby
Old 12-02-2009, 03:41 PM
djl's Avatar
djl
djl is offline
He has another post "Billet Cam Plate-Pump Conversion".
Old 12-02-2009, 09:30 PM
KumaRide's Avatar
KumaRide
KumaRide is offline
You can test it somewhat before putting everything back together by turning the rear wheel in 5/6 gear with plugs removed. You should see oil coming up through the lifters...
Old 12-04-2009, 01:01 PM
Anezangl's Avatar
Anezangl
Anezangl is offline
Thanks for all the responses people. I was away tearing the scoot back down. All nighter Wednesday thru Thursday evening.
Prodrag1320, just to see if its moving oil. Just assembled the 95" conversion, new cams and plate etc, lot of work to only have to tear it back apart because the pump moves no oil.
BAGERDSM, lifters only clacked for a short bit. She started with oil pressure but it fell off to zero as I rode down the street. Was close to home.
KumaRide, I did just that. I turned the rear wheel over and oil shot across the room from the port in the cam plate where the tensioner mounts. Also had oil coming from crank bushing etc... it appeared top be moving oil, of coarse that was after I added a wave washer that we found missing from the original pump. ( Harley Tech spotted that for me)
Will dump oil in her tonight and see what I have now.
TLew1011
03-15-2019 08:27 AM
jeffbetrollin
Engine Mechanical Topics
07-11-2016 06:45 AM
Subduedracer
Oil Archive (no new posts)
09-29-2011 06:47 PM
jwflynn
06-12-2007 12:30 PM
pococj
07-28-2006 11:39 PM
Quick Reply: Bench Test a Oil Pump?
