Dual Plug SHovelheads Ignition Choices
Old 11-27-2009, 09:25 PM
Roger Pettey's Avatar
Roger Pettey
Roger Pettey is offline
Stage I
Default Dual Plug SHovelheads Ignition Choices
Have nice set of 70 Shovel heads being bolted to a '58 Panhead bottom end. I want to use the stock timer to fire the dual 3 ohm coils. I've been told that I'll burn up the condensor after a few hundred miles. What's the right combination to make this work reliably? I'm thinking wires, coils, ignition timing, and any hook-up tricks & tips. I'm trying to stay away from the very expensive Mallory electornic ignition. Ideas?
Thanks.
Old 11-28-2009, 12:25 PM
last shovel's Avatar
last shovel
last shovel is offline
Mr. Petty,
Your issue has a simple solution;
to wit: git yer hands onna DUAL-POINT distributor, mount that sucker then follow the manual procedures for timing the double points
If you don't already have a dual-point distributor then go to the manual and see what the thing looks like; It has a different lookin point breaker cam than anything else. Remember to use the REAR points to fire the REAR cyl. And don't mix yer wires.
You might give some thought to (at least temporarily) running a cyl.head temp gauge. This effort would pay off in helping to dial-in your plug range; And, if those are short-reach heads, I recommend RGK B6L as an all around great plug to acommodate a
variaty of operating ranges. I don't remember the # for the equv. long-reach but there is one.
Hope this helps, you're on to a good thing.
Skip
P.S. if you got the patience and desire, I reccommend you set-up a (stock) retard, that is, using the left handle-bar grip, otherwise, if you forgit to retard when you kick, YOU WILL BE.
Last edited by last shovel; 11-28-2009 at 01:04 PM. Reason: wrong information on first post
Old 11-28-2009, 01:01 PM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
use 2,1.5 ohm 6v coils,wire them in series,you wont have a prob
kirby
Old 12-04-2009, 11:15 AM
stroker93's Avatar
stroker93
stroker93 is offline
The 6 volt is OK if not wired for 12 volt..I took the easier route ,, a Vulcan single fire timer,,no need to worry bout advance,,can run 2 3ohm or 2 5 ohm coils and dual plugs..The system still uses weights for timing advance..This is a 88" pan kicker only..
Dave
Nightstar57
Shovelhead
05-17-2020 04:40 PM
Teri6347
EVO
05-02-2012 06:24 PM
Woods Glen
10-23-2010 06:52 PM
TwiZted Biker
Shovelhead
06-27-2010 06:34 AM
HutchNJ
EVO
02-08-2008 11:36 AM
Quick Reply: Dual Plug SHovelheads Ignition Choices
