engine an battery light keep coming on
Old 11-26-2009, 07:06 PM
dogit56@aol.com's Avatar
dogit56@aol.com
dogit56@aol.com is offline
Stage I
Default engine an battery light keep coming on
can you give an idea were to check y does my battery an engine light come on its charging at 14+ with a new battery but the lights keep coming on an then go off in a little while .
Old 11-26-2009, 07:46 PM
EdwardK's Avatar
EdwardK
EdwardK is offline
Check the voltage regulator. Mine did the same thing when it went out. Bike ran fine and always started but would through a low voltage code. I thought it was the battery as well but turned out to be the voltage regulator.
Old 11-26-2009, 07:47 PM
hojones's Avatar
hojones
hojones is offline
Before you get to serious about it, Check your battery connections and make sure they are tight.
Old 11-26-2009, 10:34 PM
EasternSP's Avatar
EasternSP
EasternSP is offline
Received 21,796 Likes on 8,396 Posts
+1 on the battery connections. They must be tight on the battery as well as the ground connection on the starter mounting point.
Old 11-26-2009, 11:55 PM
DZLDR's Avatar
DZLDR
DZLDR is offline
+1 on that
if those are tight, then the voltage regulator is going out
Old 11-27-2009, 12:13 AM
SA315B's Avatar
SA315B
SA315B is offline
I have a similar problem but when my lights come on the voltage has dropped to 8, then 15 or so minutes later it will climb up to almost 14 and the lights go away. Or, if I shut the engine off and restart the voltage returns to normal.
Also, the check engine light will come on during or after a start and take 5 -15 seconds to go away. I just had a major service done and the dealer couldn’t find anything wrong with the battery or charging system. I have a photograph I showed to the dealer which shows the lights on and volts down to 8 @ 2,000 RPM. The bike is moving but the speed isn’t clear.
spalmer1214
05-22-2021 03:34 PM
adam31093
09-04-2013 07:29 PM
WOLFE1584
03-11-2013 05:57 PM
tekeum
09-23-2009 04:42 AM
06chrisFTW
04-11-2008 10:13 AM
Quick Reply: engine an battery light keep coming on
