sportster shut off going 50
Old 11-17-2009, 07:01 PM
Badass67stang's Avatar
Badass67stang
Badass67stang is offline
Default sportster shut off going 50
3 times over my past 2 rides my sportster has shut off while riding all 3 times i was going approx 50 in 5th gear and gunned the gas and the bike shuts off just for a split second the lil engine on the speedo lit up and the bike starts right back up because its still in gear.
any ideas?
Old 11-17-2009, 07:05 PM
Norecoil's Avatar
Norecoil
Norecoil is offline
How about the on/off switch? Do you think the contacts might be breaking down and cutting the bike off during the high speed vibration? I would also check all my wiring to make sure nothing is loose. Might start with the Bat conns first. HTH
Old 11-17-2009, 07:28 PM
cm6's Avatar
cm6
cm6 is offline
Stage II
Same problem here, doing 70 bike backfired really loud, shut off and would only crank after that. After 30 minutes of fiddling around got it to start for a few seconds then died. 1 hour later got it to run but it was horrible. One cylinder strong, rear one was intermittent. 2 hours later started back up after cleaning plugs, ran like nothing ever happenned. Long story short it was my ignition module. Mine is in my nose cone, yours should be to, i believe but not sure. Engine gets warm, ignition module fails, engine cools down, module works. Just to be safe check your coil first. It is alot easier to replace.
Old 11-17-2009, 07:29 PM
cHarley's Avatar
cHarley
cHarley is offline
STEP ONE: Read the DIY sticky thread at the top of this section for instructions on how to read the diagnostic codes. Then, report back on what you find.
Old 11-17-2009, 08:41 PM
Nonstop's Avatar
Nonstop
Nonstop is offline
Loose negative battery connection.
Old 11-17-2009, 10:16 PM
NI-STER's Avatar
NI-STER
NI-STER is offline
Loose battery connection. Me thinks Nonstop and I have had the same issue with the N.
Old 11-18-2009, 05:01 AM
bmxatv's Avatar
bmxatv
bmxatv is offline
this **** happen to me and turned out it was only running on one cylinder because this connection between the jugs came loose.
Old 11-18-2009, 10:25 AM
dlhike's Avatar
dlhike
dlhike is offline
Default EFI relay?
I had this problem with my 07 roadster when I first bought it,,,sometimes it would go days no issue then it would happen 1, 2 or 3 times on a ride. Took it in and it ended up being the fuel injector relay $20 fix...just another possibilty...
Old 11-18-2009, 12:31 PM
Badass67stang
my sportsters a carbed 05 i ran the codes before posting the thread and it said none,could jetting make it do that? my battery does struggle sometimes to start the bike since its been cold ill check the cables later to see if there loose.
Old 11-18-2009, 12:55 PM
Bulpitt's Avatar
Bulpitt
Bulpitt is offline
I had this problem for a short time & it was a relay for me also...
Quick Reply: sportster shut off going 50
