Sponsored by: Jekill and Hyde
SE heavy breather question
Old 11-07-2009, 05:27 PM
Anthony16's Avatar
Anthony16
Anthony16 is offline
Default SE heavy breather question
I initially ordered a 29515-08 se stage 1 air cleaner 58mm but changed it to the 29006-09a heavy breather air cleaner.
I have a 58 mm throttle body on my engine. The SE catalog says that the heavy breather will fit on the 50 and 58 mm throttle bodies. What I'm wondering is the heavy breather actually not the best intake for this throttle body?? Does it use some type of adapter that is actually limiting the throttle body to the size of the outlet of the heavy breather or is the heavy breathers outlet 58mm already. Maybe none of this matters in performance but I just started thinking of this and it has me concerned.
If anyone can help me out here I'd really appreciate it.
Thanks
Old 11-07-2009, 05:35 PM
skruzluce's Avatar
skruzluce
skruzluce is offline
Default plenty of air
i gotta bet you're getting plenty of air as is really and will just be adding more with the heavy breather. So i guess what i'm saying is a shortage won't be an issue and rarely is on an H-D (especially lately as they come out of the factory running near 17 on the air/fuel (13~14 being ideal) i'd probably rather it be only 50mm to choke it down some and cool er off. I assume you have an efi tuner of some sorts that will also need re-tuned to the added air-flow. My opinion only, and hope it helps some
Old 11-07-2009, 07:06 PM
Anthony16's Avatar
Anthony16
Thanks for the fast reply. I have the SE stage 4 kit installed. It comes with the SE tuner. Its suppose to be all "blueprinted" for maximum performance. Who really knows, I'll probably need more parts, Thats the Harley way , LOL. I actually didn't even pick the bike up yet but everything was just completed a week ago. I'm in Cleveland for two weeks and I went to a few dealers today to pass the time and I got to thinking about this issue.
If anyone else knows about this feel free to chime in also.
Thanks
Old 11-08-2009, 01:36 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
I have the same TB and went with the Stage 1 type air cleaner however I was at the dealer and was looking at getting the HB and I asked how the HB could fit the 50 and the 58mm TB's the answer I got was this, the adapter is needed to fit it on the 50TB and you leave it out when you install it on the 58. I am still considering the HB as there is no other air cleaner element except the HD one that works with the stage 1 style air cleaner backing plate as it requires 4 bolts to install the filter and K&N does not make a filter that size with that set up, and I am not comfortable with finding the right sized filter and plugging the 3 holes and drilling 4 new ones yet, I am worried about the plugging not the drilling.
Old 11-09-2009, 05:54 PM
Anthony16's Avatar
Anthony16
Well I went to 3 dealers over the weekend and got three different answers from their parts / mechanics.
1. That throttle body wont work with the heavy breather unless you have and adapter installed and I wouldn't do it, You're just asking for trouble when you use adapters. --- Mechanic at dealer one.
2. It will definitely work. The heavy breather bolts right up and will work a lot better than the stage one. I have one on my bike--- Parts/ mechanic guy at dealer 2.
3. I'm not sure , The SE catalog says it bolts right up with the extra screws that it says it needs. -- Parts guy at dealer 3.
Sooooooo I guess I'm going to stick with the HB and see what happens.
ib5150
01-06-2013 11:20 AM
papifun
07-10-2011 05:16 PM
hotrod88
02-20-2011 05:03 PM
WDHGS
03-23-2010 08:39 AM
ecoli
10-08-2009 03:18 PM
Quick Reply: SE heavy breather question
