What risers to use with OEM speedo mount?
Old 11-04-2009, 08:40 PM
HDDyna2006's Avatar
HDDyna2006
HDDyna2006 is offline
Default What risers to use with OEM speedo mount?
2006 FXDI, Have OEM speedo mount handlebar clamp. want to rise it from below about 2" Who makes spacer/riser to go under speedo mount clamp?
Old 11-04-2009, 08:56 PM
SuperFastGlide's Avatar
SuperFastGlide
SuperFastGlide is offline
almost any risers will work , but if you go to high youll have to extend your speedo harness
Old 11-05-2009, 05:37 AM
jmpancoast's Avatar
jmpancoast
jmpancoast is offline
I think the stock risers are 1" - 1.5" of rise. I tried 4" up and 2" back risers on mine for a couple days. It was a stretch for the lines and cables, but not too bad. Thing I didn't like was the angle and the pullback risers put the speedo. Changed it from the 35 degree stock position to more like a 50 or 60 degree angle.
Rivco Products makes a set of risers designed to give you more height and pullback while keeping the speedo at the original angle. These are pricey and there have been some fitment issues when used with the bar mounted speedo. If I remember correctly, only slight modification was needed to make them work.
Here's a link:
http://www.rivcoproducts.com/product...cat=396&page=1
Edit: Now that I have re-read your post, I am wondering if you are asking about risers or just looking to raise the speedo without moving the bars?
Old 11-05-2009, 08:45 AM
rounder's Avatar
rounder
rounder is offline
wild1 makes nice risers. standard offset bolt pattern. To go up about 2" get a 4" riser. or...http://www.spacerjim.com/index.html
Old 11-05-2009, 05:12 PM
DSmith3644's Avatar
DSmith3644
DSmith3644 is offline
Stage II
If you have the headlight visor like my 2001 FXD, then here's what I did... I tried many different risers, 4" pullback, 6" straight, but settled for a thick 4" straight set. I used two 3/8" deep-well sockets (7/16 size works fine) to use as spacer to install them onto my headlight visor. Also get longer Allen bolts of the same thread size at most any hardware store. That should to it. Relocating the sppedo to the visor allows you to use any type riser, clamp, or handlebar.
Old 11-05-2009, 06:55 PM
HDDyna2006's Avatar
HDDyna2006
No visor.
Old 11-11-2009, 07:42 PM
wes mullen's Avatar
wes mullen
wes mullen is offline
Default headlight visor
THanks for the tip. My fxd 2009 doesnt have a headlght visor, but ur right, gettin the speedo off the clamp offers lots of options. Can you still use a wind shield though? need one for a longer trip I hope to make down to Florida.
My 09 doesnt have a visor, could you tell me how the visor attaches, and maybe ill get one. thanks
wes, richmond
jtj75
Stock Harley Take Offs
02-19-2015 11:11 AM
doc_green35
03-30-2014 10:30 AM
JerryDinMD
03-16-2012 06:14 PM
Shark46
10-22-2008 02:09 PM
MattFoley
10-08-2007 06:49 PM
Quick Reply: What risers to use with OEM speedo mount?
