FLHX Air Shocks - Rough ride
Old 11-01-2009, 12:34 PM
SWAZ602's Avatar
SWAZ602
SWAZ602 is offline
3rd Gear
Default FLHX Air Shocks - Rough ride
In over a year of trying to find the magic number, I still can't get my air shocks at the right psi for a smooth ride. Too much air and I feel every crack in the road, too little and it bottoms out. I have it at 30 psi now and get a little of both with a passenger. Seriously, my FXDWG has a much smoother ride. I'm about ready to give up and get some other kind of shocks.
Any suggestions on psi for the air shocks? I am 190# and passenger is 160#.
Any suggestions on different shocks?
Old 11-01-2009, 12:37 PM
jasilva's Avatar
jasilva
jasilva is offline
If you can afford them-Ohlins
If those are out of reach-Progressive 440s or 412s if your really pinched for cash.
Old 11-01-2009, 12:38 PM
HDV-GLIDE's Avatar
HDV-GLIDE
HDV-GLIDE is offline
Replace them with coil (spring) over shocks....Ohlins are a great choice....
See here: http://76.162.149.2/gpage32.html
Old 11-01-2009, 12:39 PM
StreetGlider56's Avatar
StreetGlider56
StreetGlider56 is offline
Same here, got mine clocked in for riding solo but I ad my 13 year old daughter (105lbs) and it bottoms out... going to try progressive shocks see how they work out...
Old 11-01-2009, 12:42 PM
HDV-GLIDE's Avatar
HDV-GLIDE
For close to the price your pay for the Progressives, you can get the Ohlins, which are made to your specs....It's your money though, do what you thinks best....
Old 11-01-2009, 12:55 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
At the very least price the Ohlins before buying Progressives, mine were less $ than the 440's or the 430's.
Old 11-01-2009, 03:46 PM
Plow64's Avatar
Plow64
Plow64 is offline
If you're talking about the OEM shocks on an FLHX, they are the low profile 12" shocks and they ride kind of harsh. I fixed the issue by picking up a set of 13" Ultra shocks off e-bay. The extra 1" shock travel smoothed out the ride. The bolt right on, no problem.
Old 11-01-2009, 03:49 PM
jasilva's Avatar
jasilva
jasilva is offline
Really? I wanted the Ohlins but was looking at $250 more for them. I'd switch out if I could get the Ohlins cheaper and sell off my Progressives. The Progressives are definitely a step above stock but I love the Ohlins on my enduro bike.
Old 11-01-2009, 04:38 PM
Streetrunner's Avatar
Streetrunner
Streetrunner is offline
I have an '06 SG and never found that magic number either but I did find a solution that has worked very well for me. I installed standard 13" HD air shocks and couldn''t be happier. The ride is the way is should be. no more bottoming out and very smooth over most bumps in the road.
The best part is nobody has ever noticed that my SG sits a bit higher. It's virtually unnoticable so why suffer?
Old 11-01-2009, 05:20 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
Default Price Difference
I only know that the list price on 440's is 599.00 and i think the 430's are 499 list, my Ohlins #2 version 13 1/4 inches long were less from Motorcycle Metal, a forum sponsor.
Quick Reply: FLHX Air Shocks - Rough ride
