Clutch hub removal
Old 07-07-2006, 07:34 PM
300E's Avatar
300E
300E is offline
Default Clutch hub removal
I got my friends 73 superglide the other day. I am trying to pull the clutch hub off the mainshaft. I have a large 3 jaw puller on it but it dosen't budge. the hub is distorted from the puller so it will be replaced. How has anyone else got a stubborn one off? thanks
Old 07-07-2006, 09:29 PM
pococj's Avatar
pococj
pococj is offline
Default RE: Clutch hub removal
They make a puller for HD clutch hubs. Yours is probably frozen on. Generally they can be gotten off by putting pressure on the puller, then whacking the center bolt with a hammer, putting a little more pressure, whacking, etc. Unless it's completely rusted/galled to the shaft, it'll suddenly pop off and scare the crap outten ya. Some heat might help, but be careful not to ruin the temper of the shaft.
Old 07-08-2006, 06:09 PM
dracos's Avatar
dracos
dracos is offline
you can make a puller for the clutch hub if you have a round piece of steel laying around, just drill clearance holes for the studs on the hub and drill and tap a hole in the center for a 1/2" x 13 bolt. Take the nuts off of the studs on the hub, put the puller on and replace the nuts. Take a long 1/2" bolt and grind about a 60 degree angle on the end and screw into the center of the puller. It will push up against the center of the mainshaft and pop the clutch hub off. The end of the mainshaft and the inside of the clutch hub are a matched taper with just a piece of keystock and keyway to keep it from spinning.
Old 07-09-2006, 01:04 PM
76hdfxe's Avatar
76hdfxe
76hdfxe is offline
Had the same problem on my 76. Spent $30 on a puller from J&P and it makes life a lot easier.
Old 07-09-2006, 10:12 PM
300E's Avatar
300E
300E is offline
I got the hub off with my puller and heat. Now I think the end of the mainshaft is distorted. The hole for the pushrod is off center.My guess is I'm now rebilding the transmission . My question now is where is a good place for used transmission parts? thanks.
daven9113
EVO
15
07-07-2021 10:50 AM
hd1340bmw
EVO
04-12-2018 12:13 AM
mikeb7
02-22-2009 09:33 PM
Eagle_SC
EVO
04-25-2007 05:46 PM
antoniov1
Shovelhead
12-18-2006 10:53 PM
Quick Reply: Clutch hub removal
