S&S 570 Cams
Old 10-29-2009, 02:25 PM
ghostrider69's Avatar
ghostrider69
ghostrider69 is offline
Default S&S 570 Cams
I ran into an old bud of mine this morning and he was on his 98' Dyna. He had just installed a 95" big bore kit. He did not have any head work done and was running an S&S 570 cam and for exhaust he had a set of Samson Street Sweepers. Man I tell you what that thing sounded freekin nasty. I was wondering if anyone knew if you can install these cams in a stock 96". I have already checked and they are available for 06' up. I just think that if he can install one in a 95" engine then I should be able to install them in a 96" engine. Or am I wrong?
Old 10-29-2009, 02:35 PM
paul s's Avatar
paul s
paul s is offline
570 is getting into the needing new springs zone, I "think" our beehives are good to 550.
Old 10-29-2009, 02:53 PM
thedonthere's Avatar
thedonthere
thedonthere is offline
+1, call S&S and ask them
Old 10-29-2009, 03:39 PM
paul s's Avatar
paul s
paul s is offline
"We have found that when using cams with lifts of .575 or less that the new beehive spring kits from HD work excellent." / This is from the NHRS Performance site, I guess they can handle more than I thought. http://www.nrhsperformance.com/headworktc.shtml
Old 10-29-2009, 07:02 PM
comaman2's Avatar
comaman2
comaman2 is offline
s&s reccommends you up grade the springs when using the 570 cams
Old 10-29-2009, 07:42 PM
kennyfatboy's Avatar
kennyfatboy
kennyfatboy is offline
Default Yeah but how does it run
What are the gains to adding lumpier cams ,,h,power? top end ? torque has anyone dyno tested before and after,,,I think that might be the way to go .
Old 10-29-2009, 09:02 PM
SC-Longhair's Avatar
SC-Longhair
SC-Longhair is offline
Cams are designed to produce power in various points of the powerband. Low, mid, top. Picking the right one to compliment your riding style is the key. Most harley want a cam that makes low-midrange power. Top end is a waste.
Old 10-29-2009, 11:00 PM
TOMCENTRAL's Avatar
TOMCENTRAL
TOMCENTRAL is offline
mrsnipy
03-08-2019 10:45 AM
ChromeJunkie
01-25-2016 12:53 AM
black classic
11-02-2007 10:01 AM
trigger1911
Exhaust System Topics
23
05-23-2007 05:55 PM
Meathooks
01-23-2006 07:53 AM
Quick Reply: S&S 570 Cams
