1990 FLH Starter problem
Old 10-23-2009, 09:03 AM
Delawaredave's Avatar
Delawaredave
Delawaredave is offline
Default 1990 FLH Starter problem
1990 FLH. First time I hit starter, I get this dragging/grinding sound like something needs lubricated. Second time it's better.
I couldn't see lubrication instructions in service manual.
How do I get at to lubricate ? There's a round 3" inspection port on left side - can I access that way ?
Thanks for your help !
Old 10-23-2009, 09:47 AM
MILO851's Avatar
MILO851
MILO851 is offline
Welcome to forum
Sounds like the starter solenoid is not engaging far enough and starter is spinning before it is fully engaged. check and tighten all cables to battery otherwise may need starter rebuilt or replaced
Old 10-23-2009, 12:13 PM
grbrown's Avatar
grbrown
grbrown is offline
I have had my 1990 bike from new and suffered similar problems some years ago. There is no lubrication in the starter, my problem was the starter clutch, which I replaced. Was pretty straight-forward and the same starter is still working OK with my recent new S&S 107 motor!
Old 10-25-2009, 03:42 PM
Delawaredave
Originally Posted by MILO851
Welcome to forum
Thanks a bunch for above. I cleaned terminals and it seems a lot better.
Have a great day !
Old 10-25-2009, 04:42 PM
EGlideKid's Avatar
EGlideKid
EGlideKid is offline
One other thing to check, your starter bolts may be loose. It's not unheard of and one of two things happen when they are, you either get nothing when you hit the starter button or, you get a grinding noise. Check them out as well.
Old 10-26-2009, 06:58 AM
MILO851's Avatar
MILO851
MILO851 is offline
NO problem ride safe
TrickyNicky
Shovelhead
10-26-2017 09:57 AM
69z28
Shovelhead
02-25-2017 02:05 PM
curtisldean
01-15-2016 12:42 PM
captwill55
Shovelhead
04-13-2014 07:36 PM
Vulcun
05-20-2011 10:40 PM
Quick Reply: 1990 FLH Starter problem
