Flywheel & Compensator Shims for Primary Alignment
Old 10-15-2009, 12:06 PM
esport_evan's Avatar
esport_evan
esport_evan is offline
1st Gear
Default Flywheel & Compensator Shims for Primary Alignment
Hi guys, I have a question here as I'm working on updating our Harley parts application list. We have a 3-phase stator/regulator conversion kit for Harleys, but I've recently noticed some fitment problems with various models of bikes.
What I need to know to narrow this down is about the shims used on the crankshaft for primary chain alignment. Unfortunately, I'm not very familiar wit Harleys, and need to clarify some mechanical issues so I can ensure our stator fits correctly.
I'm attaching a picture to show what I believe is the correct layout under the primary cover:
This is drawn looking down on the primary case internals from above.
The crank is in black at the top, with the stator in blue, mounted to the engine sidecase.
The rotor/flywheel is in pink, and covers the stator.
The shims are in green on the outside of the rotor.
The compensator sprocket (is this the right name?) is in black outside the shim, along with the locking nut.
The chain is dotted black lines.
The clutch is on the bottom.
I have a few key questions:
1)
How is the rotor held in place on the crankshaft?
Is the shaft tapered and has a woodruff key? Or is it splined?
The main thing I need to know here, is if the rotor slides onto the crankshaft to a certain point, and is fixed at that location...ie it is a fixed distance away from the stator windings.
2)
Where are the shims to align the primary chain located? From my understanding in my above drawing, the shims are located between the rotor and the countershaft sprocket, to allow you to adjust the alignment of the primary chain in line with the teeth on the clutch basket.
3)
Are these shims the only adjustment of the primary chain alignment?
From what I've read lurking through the forum it sounds like the transmission and therefore the teeth of the clutch sprocket can be adjusted too?
Thank you guys very much for giving me some information on these points!
Evan
Old 10-16-2009, 09:56 AM
rbabos's Avatar
rbabos
rbabos is offline
Rotor is fixed postion as well as the stator. No shims. You need to get you hands on either used parts or the actual bike to confirm fit up and dimensions. Fastest way I know of. Both components are simple as dirt, once you see them but have the price of gold.
Ron
Old 10-19-2009, 11:25 AM
esport_evan
1st Gear
Hi Ron,
Thanks for the info.
I talked to a Harley Tech at a local dealership last Friday, and he confirmed this.
That was exactly what I needed to know!
I appreciate the help.
ccryder
12-10-2012 09:35 AM
Dysfunctional
EVO
09-02-2012 08:28 PM
sharkey
03-23-2012 08:59 PM
heavypic
07-13-2009 04:55 PM
air2mud
02-01-2006 01:20 PM
Quick Reply: Flywheel & Compensator Shims for Primary Alignment
