Road King Handlebars Change Video
Old 10-06-2009, 08:43 AM
shortride's Avatar
shortride
shortride is offline
Default Road King Handlebars Change Video
Has anyone here made a video on how to change handlebars on a Road King? It sure would be handy for those that may need a little help and be able to save some money.
Old 10-06-2009, 12:41 PM
huffhuff's Avatar
huffhuff
huffhuff is offline
Hardest part is getting the bar clamp cover off. you have to remove the headlight to loosen the nuts on the trim spear and the front of the clamp cover. don't remove the nut from the screw on the clamp cover to prevent loss into the black hole there. the cover will be removable with careful manuevering.
Old 10-06-2009, 04:37 PM
bikehunter's Avatar
bikehunter
bikehunter is offline
I done the job OK. I removed the screen, head light rim (dont lose the sprung wire, then the headlamp, once inside that, undo the nut under the shell for the top trim, then the one further inboard but not fully, just loose.
Undo one side of the headlight shell, 2 nuts on the side and split the sheel slightly to enable the top trim to slide out.
The cover over the handle bars have 2 bolts under the ignition cover which can be prised off slowly. There may be snap bolts instead of bolts so you will have to tap them round with a punch and slot them to replace.
Sorry no video
Old 10-06-2009, 04:55 PM
JonnyD's Avatar
JonnyD
JonnyD is offline
Do they make a tape that can handle that many hours
Seadweller
06-01-2019 08:38 AM
sealbeachbum
10-03-2012 11:58 PM
mikelikesbikes
09-15-2012 12:16 PM
cheintze
General Topics/Tech Tips
06-21-2010 03:08 PM
Petesnot
05-23-2009 07:11 AM
Quick Reply: Road King Handlebars Change Video
