Rear Wheel Alignment
Old 09-28-2009, 11:05 AM
harley1425's Avatar
harley1425
harley1425 is offline
Default Rear Wheel Alignment
Changed my rear tire to an Elite 3, (fantastic tire) and after a couple of weeks I checked the belt and it was a little loose. Went to adjust it and don't understand how to make sure the wheel is straight. Most bikes have an adjuster on both sides with graduations stamped on the swingarm, not Harley. Why they use those cams I don't understand. If someone could give me a quick way to make sure the wheel is straight I would appreciate it.
Old 09-28-2009, 02:41 PM
07SG's Avatar
07SG
07SG is offline
The cams ensure that axle has moved an equal distance on each side.
Old 09-28-2009, 03:35 PM
418S's Avatar
418S
418S is offline
I'm assuming you've put the (removeable) cam on the correct way.
If you examine the cams you'll see how they butt up against the welded nub. As you turn the welded nut the wheel is pulled back and the belt tightens. It would be impossible for the wheel to be out of alignment - loose belt maybe - out of alignment nana!
fatboy9nc
Wheels/Tires
02-06-2017 05:00 PM
LX2
2014-2023 Touring Models
03-04-2016 12:51 PM
semiret
09-10-2014 11:03 PM
Tucker99
04-05-2014 08:20 AM
Ragtop
05-08-2012 01:13 PM
Quick Reply: Rear Wheel Alignment
