Throttle By Wire Plug Diagram
Old 09-22-2009, 05:16 PM
ms_weasel's Avatar
ms_weasel
ms_weasel is offline
3rd Gear
Default Throttle By Wire Plug Diagram
Does anyone have a wiring diagram for the TBW connector in the bars?
I am working on internal wiring and new bars, stupid me tried to pull the connector through the bars and needless to say it broke off in the bars. Now I have got all that extra stuff out of the bars (the broke conector) I need to solder my wires togehter before my next attempt. The throttle itself has a red, white and black wire on each side of the connector, the other pigtail ( leading to the fairing) has six other wires of different colors.
I need to know which wires to solder together.
Wrecks SUCK!
sometimes fixing it back like it was seems a whole lot easier, but not near as cool!!!
Thanks,
ms_weasel
Old 09-22-2009, 06:07 PM
dawg's Avatar
dawg
dawg is offline
Received 2,960 Likes on 1,713 Posts
Old 09-24-2009, 12:12 PM
JohnK/Pa's Avatar
JohnK/Pa
JohnK/Pa is offline
I hope your not trying to extend the wiring for the Throttle By Wire. If you are the throttle won't work. If you want extended wiring you have to buy a whole setup from HD thats resistance calibrated for the longer wires so the TBW will work.
Old 12-07-2010, 03:12 PM
scott236000's Avatar
scott236000
scott236000 is offline
Stage I
a little help also...i took the wires out of the pulg to pull them through the bars.not relaizing that NONE of them go to the same color..could someone post a what goes to what for a 2010 flhx
Old 07-09-2011, 06:46 PM
RepoMike's Avatar
RepoMike
RepoMike is offline
Not true, throttle works fine just don't mix up the wires.
Teddyboy (03-07-2020)
Old 12-11-2011, 11:35 AM
graultytc88's Avatar
graultytc88
graultytc88 is offline
I was told the same thing by a rep at Zippers about not cutting the wires from the throttle. You've done this yourself without any problem?
Old 12-11-2011, 11:39 AM
PistonPuller's Avatar
PistonPuller
PistonPuller is offline
A lot of people have cut the TBW and spliced new extensions. Someone sells an extension kit to do so. I didnt do it on mine, but I did wrap the connector with electrical tape so it would not come apart. I think if I were having to extend the wires, I would just buy the SE TBW replacement.
medicmouse
Electrical/Lighting/Alarm
08-02-2017 09:46 AM
gpp
05-12-2016 01:47 PM
jmoser
09-25-2013 07:31 PM
gtrplyr
07-30-2010 11:00 AM
TOMMY M
08-27-2009 06:07 AM
Quick Reply: Throttle By Wire Plug Diagram
