Air cleaner puking out oil ... twin cam
Old 06-20-2006, 07:36 PM
Ultra RB's Avatar
Ultra RB
Ultra RB is offline
Default Air cleaner puking out oil ... twin cam
I have a 1999 Ultra, 95", 50k miles on it. Engine rebuilt 5k ago by a reputable dealer, runs like a top, better than ever.
But, the other day I noticed oil had puked out of the air cleaner and dripped onto the crankcase ... clean oil (changed 1k ago). Also some sprayed onto the rear header pipe.
What causes this? Is it harmful? Should I do anything about it ... or just enjoy the aroma?
Thanks.
Old 06-20-2006, 08:30 PM
Kahuna's Avatar
Kahuna
Kahuna is offline
Default RE: Air cleaner puking out oil ... twin cam
Ultra,
There are two sources where the oil is coming from. First, if you have a K&N Stage I (reusable) air filter, it requires oiling after the service. This could drip out if oversaturated. The other source is the engine oil mist that is coming from the crankcase vent. The way this "supposed" to work is when the oil mist comes out through the holes in the air filter backplate, the suction from the air intake is supposed to suck it back into the engine. Thus, no drips! However, that theory never worked too well. Most baggers with the TC88 engines can be sure to see some oil dripping from the air cleaner from time to time.
What you can do:
- Make sure that your engine oil is not overfilled in the crankcase.
- Try the new HD (blue) air filter. This one doesn't need to be oiled.
- Keep your engine properly tuned. Backfires can force more oil to the filter.
- Occasionally wipe the inside of the air cleaner to remove excess oil.
Hope these help.
Kahuna
ORIGINAL: Ultra RB
Thanks.
Old 06-21-2006, 11:22 AM
100thRK's Avatar
100thRK
100thRK is offline
What Kahuna said. It is normal.[sm=exactly.gif][sm=trust_me.gif]
ORIGINAL: Kahuna
Ultra,
What you can do:
Hope these help.
Kahuna
ORIGINAL: Ultra RB
Thanks.
Old 06-21-2006, 02:12 PM
Ultra RB's Avatar
Ultra RB
Ultra RB is offline
Kahuna/100thRK ...
Thanks for the advice.
Yes the oil level is at the high mark, I'll suction a bit out. I also removed and cleaned the K&N, there was some engine oil residue but not a lot. Funny thing is this bike has never done this before so I suspect it's the oil level thing, maybe I put a bit too much in this last oil change.
Thanks again and good riding to you.
Old 06-21-2006, 02:32 PM
turbo54's Avatar
turbo54
turbo54 is offline
I have v@H breathers that driped oil into the air cleaner. I ran a hose from each port and down and out the sides .
[IMG]local://upfiles/3159/FB1AC44F02EF46F6BE2474DFD13951D5.jpg[/IMG]
Old 06-21-2006, 03:02 PM
Kahuna's Avatar
Kahuna
Kahuna is offline
Sounds good Ultra RB. I had the same problem with my Road Glide, but it seemed to have gone away, now that I've changed to the new HD (blue) air filter. It seems to create a better seal with the backplate, so the oil is being sucked back in more efficiently.
ORIGINAL: Ultra RB
Kahuna/100thRK ...
Old 07-04-2006, 02:59 PM
hmarcley's Avatar
hmarcley
hmarcley is offline
Stage II
i have a 2000 road glide efi wich puked oil from filter when ridden at high rpm or for long periods. Harley informed me problem was the oil pump, I rebuilt eng. 5 days ago went with 1550 kit w/cams also upgraded oil pump to solve problem. Rode bike around city eng. performance was great. got it up on interstate to see what she could do 10 miles in eng puked 1 qt of oil from housing, covering new eng. and paint. Oil psi dropped to 5psi, i limped it home but am discouraged problem still exists.oil is pumped to top end to fast and has noware else to go. any ideas would be appreciated. It wasnt over filled and was a Qt and 1/2 low after ride.
Old 07-04-2006, 03:43 PM
bountyhunter's Avatar
bountyhunter
bountyhunter is offline
1 1/2 quarts low, that is BRUTAL!
ricklee4570
04-26-2018 01:28 PM
Liquidoxygen
2014-2023 Touring Models
08-17-2015 11:58 PM
rdrunner
09-29-2014 07:51 AM
woosh
06-30-2011 10:45 PM
Mike5959
06-11-2010 09:46 PM
Quick Reply: Air cleaner puking out oil ... twin cam
