steering damper/stabilizer
Old 09-18-2009, 11:09 AM
elmo771's Avatar
elmo771
elmo771 is online now
Default steering damper/stabilizer
I was going to add a steering damper to my wife's1200 triketo help with a low speed wobble. I have found a used one but he has lost the instructions. Does anyone who has installed one have the instructions that they can email or copy for me? Thanks
Old 09-18-2009, 02:37 PM
cHarley's Avatar
cHarley
cHarley is offline
I would think the instructions might be dependent on the manufacturer of the stabilizer. Is this a HD product?
Old 09-18-2009, 03:48 PM
elmo771's Avatar
elmo771
Harley doesn't make one, this is a aftermarket. I emailed the company that it was bought from but the have never responded.
Old 09-18-2009, 04:36 PM
FastHoss's Avatar
FastHoss
FastHoss is offline
Please try to resolve her issue by normal means first.A dampner is a good thing put like pain pills it can mask a serious underlying cause.
Old 09-18-2009, 04:47 PM
FastHoss's Avatar
FastHoss
FastHoss is offline
It probably involves needing more rake.A true trike expert can tell you for sure.
Old 09-18-2009, 05:03 PM
elmo771's Avatar
elmo771
I think your right. I am going to put on a new tire, check the neck bearings and then go from there.
Old 09-18-2009, 05:05 PM
Certainteed's Avatar
Certainteed
Certainteed is offline
low speed wobbles are almost always tire-balance.
Old 09-18-2009, 06:11 PM
jag1886's Avatar
jag1886
jag1886 is offline
Sounds like you may need some raked trees instead of a stabilizer, that's how they fix that problem on the big bikes.
Old 09-18-2009, 06:39 PM
turn8a's Avatar
turn8a
turn8a is offline
Is it a shindy daytona damper?
Old 09-18-2009, 08:13 PM
elmo771's Avatar
elmo771
No it not But It looks almost like it. It was from a place called fog hollow, If I do get one is the shindy the one to buy
Quick Reply: steering damper/stabilizer
