more hp and torque for nightster?
Old 09-14-2009, 07:04 PM
shon517's Avatar
shon517
shon517 is offline
Default more hp and torque for nightster?
hello all, Im new to this and have a question. I have a 2008 nightster 1200. I got V&H sideshots on it and I put a SE pro super tuner w stage 1 EFI kit also. I still would like some more HP and Torque. on the dyno it only had 69.8 trq and 70.2 hp. What are my options?
Old 09-14-2009, 07:45 PM
SPECIAL ED's Avatar
SPECIAL ED
SPECIAL ED is offline
Change your exhaust or cams, maybe have your heads reworked.IMO the popular short exhaust systems aren't worth a crap for power you'd do better with a decent 2 into header or something like true duals where both head pipes are equal length.
Old 09-14-2009, 09:01 PM
fox4's Avatar
fox4
fox4 is offline
The next step for power is definitely head work. It will definitely give the most bang for your buck. The full effect of cams will not be felt with the crappy heads that come on the sportsters from the factory.
Old 09-14-2009, 09:17 PM
midnight2005's Avatar
midnight2005
midnight2005 is offline
I have to agree, you can do alot by yourself. get out the dremel and polish those heads and add some bigger better valves.
Old 09-14-2009, 09:24 PM
BucksBike's Avatar
BucksBike
BucksBike is offline
Wouldn't the heavy breather be the next step?
Old 09-14-2009, 09:46 PM
xFreebirdx's Avatar
xFreebirdx
xFreebirdx is offline
Time to open your wallet and pray to the power gods.
Old 09-14-2009, 11:27 PM
bwana1's Avatar
bwana1
bwana1 is offline
Get the "SUPER HAMMER" kit from Zippers Performance. Pricey! But, it will take you very close to 100/100 for hp and tq and it remains 1200 cc.
Bwana
Old 09-15-2009, 03:04 AM
Fast FLHX's Avatar
Fast FLHX
Fast FLHX is offline
Get a trask turbo.
Old 09-15-2009, 06:54 PM
jag1886's Avatar
jag1886
jag1886 is offline
You need head work and compression and loose those gaybag pipes. My wifes 2003 makes more HP and Torq that your's and hers has a mild Zippers Torqster kit.
You'd be amazed at what a good 2-1 exhaust and a new tune would do.
You have a good set of cams from the factory I would not worry about those.
madmax442
08-15-2010 01:08 PM
wickedneck
05-12-2010 07:21 AM
madmax442
05-08-2010 03:10 AM
NCTURBOS
Exhaust System Topics
13
11-19-2008 07:42 AM
Suede Blue Man
09-21-2008 03:15 PM
Quick Reply: more hp and torque for nightster?
