Sportster Rear Wheel Removal?????
Old 06-14-2006, 07:41 PM
socalsoftail's Avatar
socalsoftail
socalsoftail is offline
Default Sportster Rear Wheel Removal?????
I have removed the rear wheel before on a harley just not the sportster. The bike has 12k mi on it and the rear wheel has never been off. The bike needs a new tire so i losened up the axel and took the belt off then removed the cotter pin nut and washer. Now the serivce manual says to gently tap the axel until lose then slide it out. This axel aparently likes its home and does not want to leave the bike. Any ideas? I have put some muscle into it and its not moving. Also it was really hard to slide the wheel forward to remove the belt. Its an 02 883c Thanks
Old 06-15-2006, 02:16 PM
socalsoftail
Default RE: Sportster Rear Wheel Removal?????
Nevermind it finaly came out! ......... I don't know why but it was not easy to get out
Old 06-15-2006, 11:42 PM
spikehyre's Avatar
spikehyre
spikehyre is offline
When you re-install use an anti-seize lube on the axle.....will make your life much easier.
Old 06-16-2006, 06:47 AM
cootertwo's Avatar
cootertwo
cootertwo is offline
I've read that the "spacer" is what usually freezes up on the axel.[:@]
Old 06-18-2010, 06:29 AM
GT_RoadGlide's Avatar
GT_RoadGlide
GT_RoadGlide is offline
If you had to "beat" it out you should change the bearings. Clean up the old axle and if it doesn't slid in then time to replace it. I use a multi-marine grease on mine when it is time for reassembly. I apply a thin film to axle and both spacers.
Old 06-18-2010, 07:18 AM
cHarley's Avatar
cHarley
cHarley is offline
I'll bet he already figured this out, seeing as the thread is 4 years old.
skeetb1100
04-29-2019 11:18 AM
Kenjr
07-31-2012 08:21 AM
j jacks
01-13-2012 05:49 PM
WarriorHD
03-16-2007 08:13 PM
ckamin
20
03-22-2006 10:59 AM
Quick Reply: Sportster Rear Wheel Removal?????
