power cammander or vance and hines fuel pack???
Old 09-08-2009, 01:42 PM
slickmyster2004's Avatar
slickmyster2004
slickmyster2004 is offline
2nd Gear
Cool power cammander or vance and hines fuel pack???
Im gonna purchase vance and hines straight shot slip ons a, and a arlen ness stage 1 or stage 2 breather, which is better, the power commander or the fuel pack from vance and hines or is there even any differance?? Im not sure what to go with.
Old 09-08-2009, 02:15 PM
big_e78's Avatar
big_e78
big_e78 is offline
I've used both. If you have an 07 or later, you'll get error codes with fuelpak because of o2 sensors. Pci seemed to increase throttle response too.
Old 09-08-2009, 02:36 PM
golfblues's Avatar
golfblues
golfblues is offline
Received 1,434 Likes on 874 Posts
I have an 09 with a Fuelpak & have not received any error codes at all. I have Fuelpaks on both bike & they are great. I picked them up new for 150-175 each so the price was right & the install was easy. They work fine for me.
Old 09-08-2009, 02:55 PM
Mike's Avatar
Mike
Mike is offline
This has been discussed quite a few times here and on other HD forums. Do a search for fuelpak vs power commander here and on google. Lots of good info already out there.
If you're not planning on doing much beyond slip-on's and an air filter, the fuelpak is probably sufficient, and at an attractive price. You can go to the fuelpak website and plug in the data for your configuration and see right away if they have a map already built.
http://www.fuelpakfi.com/harley1.html
Old 09-08-2009, 06:15 PM
BlackRob's Avatar
BlackRob
BlackRob is offline
I have used both. I like the Power Commander but before you buy one make sure they have a map for your set up in their data base. I ordered V&H Double Barrels and a PC3 only to find out that there is no map even close for the pipes. V&H customer service would not give me a map either. I bought the Fuel Pak and have been using it since. No complaints with it.
Old 09-08-2009, 06:29 PM
username17's Avatar
username17
username17 is offline
I've only used the PC5. But I really liked it.
I called the company that had it and they programmed it for free.
It was easy to install and with the fake O2 sensors the ECU is happy.
surfnorthwest
2014-2023 Touring Models
07-26-2014 03:18 PM
Bushy
07-29-2013 07:34 PM
mmazz365
04-10-2012 05:52 PM
sg29651
06-29-2008 02:52 PM
navyman
Exhaust System Topics
09-09-2005 09:36 PM
Quick Reply: power cammander or vance and hines fuel pack???
