Handlebar shake
Old 06-09-2006, 03:32 PM
slack's Avatar
slack
slack is offline
Default Handlebar shake
I have a 05 Heritage and when I let off the gas and comming down from 50 mph or less the handlebars shake. It is not too much just a little. My question is, does the head nut need to be tightend? Or what is the best choice of action?
Old 06-09-2006, 04:48 PM
L night train's Avatar
L night train
L night train is offline
Default RE: Handlebar shake
i have a 06 night train with a spoked rim it does it to
Old 06-09-2006, 07:06 PM
barrygreen's Avatar
barrygreen
barrygreen is offline
Put your bikes on a lift and check the fall over. I bet your steering head is too lose. Mine did the same thing
and that is what it turned out to be. With the bike on the lift if you touch the handle bars and the front
end just "falls" to one side the steering head bearings are too loose. The guys at the HD shop recommended
that they be adjusted a little tight, book calls for 2" fall over and they suggested 3". There is a procedure
for this in the manual but it is pretty simple. With the bike on the lift tape a piece of string to the bottom
of the rear fender. Put some type of weight on the end of the string to where the weight is just off the
floor then put marks on the floor or use a yard stick. With the front wheel straight slowly push the end
of the bar and watch the inch marks to see where the wheel begins to fall over by itself. should
start at about 2" of movement, if not tighten the bearings.
I tried tightening the spokes and checking the tightness of the swing arm but it turned out to
be that the steering head was loose, after tightening that no more wobble and it is like riding a different
bike as far as handling goes.
Note: some bikes require that you remove items like the clutch cable to check this.
Barry
Old 06-09-2006, 11:47 PM
L night train
do you know the tourqe spec .THANKS
Old 06-10-2006, 12:16 PM
barrygreen's Avatar
barrygreen
No tourqe speck for the steering head nut, just adjust the fall away.
Barry
ORIGINAL: L night train
Old 06-10-2006, 01:30 PM
midwesttom's Avatar
midwesttom
midwesttom is offline
My 06 did the same thing it was stering head loose at 1000 miles look for the post of mine. Many people said it was the spokes I don't think you should mess them if you don't know how. The stering head being tightened fixed mine. Good luck
Old 06-10-2006, 03:04 PM
slack's Avatar
slack
slack is offline
Hey thanks guys, That was what I thought it was nice to get a good second opinion on the subject. Just another geat reason to be apart of the forum.
Old 06-10-2006, 07:26 PM
PhantomMaxx's Avatar
PhantomMaxx
PhantomMaxx is offline
Forgot to add a front image... here ya go
Old 06-19-2006, 08:34 PM
L night train
i had my stering berings adj shake all gone and all no charge
KrustyKush
Milwaukee Eight (M8)
06-11-2019 02:32 PM
JekyllnHyde
04-08-2011 11:40 AM
crepe
05-17-2010 07:02 AM
az426hemi
01-26-2009 09:46 PM
grumpy irish again
04-10-2006 04:59 PM
Quick Reply: Handlebar shake
