Sponsored by: Jekill and Hyde
HD Lifters?
Old 06-06-2006, 12:20 PM
Jonpaul's Avatar
Jonpaul
Jonpaul is offline
Default RE: HD Lifters?
I have the S&S lifters on my bike, seem to work fine. Also, when you have your gear driven cams installed, consider installing an S&S reed valve at the same time. It will correct any oil blowback coming from your air cleaner. It's a simple install while they have the cams out.
Old 06-06-2006, 04:37 PM
Sleeps In Trees's Avatar
Sleeps In Trees
Sleeps In Trees is offline
thanks jonpaul.
Old 06-06-2006, 05:43 PM
Spectrexx's Avatar
Spectrexx
Spectrexx is offline
Use the stock lifters. They will work perfectly in just about any engine no matter what mods have been done. No need to waste money on more expensive ones unless it's a race bike. Even then, I've built some 100+ ft lb engines that I raced every weekend for a few years before needing to replace them. Those were some HARD miles and they held up great.
Old 06-06-2006, 06:53 PM
Sleeps In Trees
Thanks Spectrexx, the stock ones on there seem to be working fine so that's what I'm gonna do.
Old 06-07-2006, 04:19 PM
Spectrexx's Avatar
Spectrexx
Good choice. If you mean getting NEW stock lifters, that is. If you have 47k on the engine already, then now is a good time to change them. They are easy enough to change later if you have to.
harley#1
Engine Mechanical Topics
03-05-2019 10:51 AM
xcbullet
08-27-2015 07:53 PM
ChromeJunkie
07-15-2010 07:20 PM
the4thgearkid
12-06-2009 10:29 AM
Quick Reply: HD Lifters?
