Oil drain plug location?
Old 08-19-2009, 06:38 PM
elvis8310's Avatar
elvis8310
elvis8310 is offline
Default Oil drain plug location?
Ok, I am working on a 2002 Fatboy. Which plug do I pull to change the oil? Pics if possible please.
Old 08-19-2009, 07:15 PM
Dorkman's Avatar
Dorkman
Dorkman is offline
Suggest you use the search feature and/or get a manual.
Old 08-19-2009, 07:35 PM
RocketRocker's Avatar
RocketRocker
RocketRocker is offline
Located under the frame directly under the oil tank. The bolt almost is like on the frame on the bottom...
Old 08-19-2009, 07:41 PM
elvis8310's Avatar
elvis8310
I used the search and nothing came up. That is why I asked and it is not my bike so why would I have a manual for it. I am just helping a friend who got back from Iraq last night.
Old 08-19-2009, 08:13 PM
keno's Avatar
keno
keno is offline
elvis, thank your buddy for his service. My son just returned a couple weeks ago.
Old 08-19-2009, 08:18 PM
Called2Duty's Avatar
Called2Duty
Called2Duty is offline
so you have a 2000 Fatty, and didnt know where the drain plug is?! or just didnt want to tell him
Old 08-19-2009, 08:22 PM
silvrbill's Avatar
silvrbill
silvrbill is offline
Uhhh..maybe look under the oil tank?
Old 08-19-2009, 08:37 PM
Crackerman's Avatar
Crackerman
Crackerman is offline
follow the rubber hose that leaves the oil tank, it is at the end of this hose :-) Probably terminated in a piece of the frame real close to the right pass footpeg.
Old 08-20-2009, 05:40 AM
hpfatboy's Avatar
hpfatboy
hpfatboy is offline
2ND THAT, underside of frame below oil bucket. CARB SIDE.
Old 08-20-2009, 05:52 AM
Mark R's Avatar
Mark R
Mark R is offline
look at the bottom of the frame under neath the oil tank, it is near the rear leg jsut in front, it is a hex head bolt 5/8 socket and has a allen key fittin inside asweel
the gear box drain is up under between the 2 shocks, it is also a 5/8 headed bolt
the primary drain is located at the rear, jsut under the derby cover, it is a torx fittin
SimonR (05-15-2019)
Quick Reply: Oil drain plug location?
