location of security module or smart security system
Old 08-14-2009, 08:55 AM
manborn's Avatar
manborn
manborn is offline
Default location of security module or smart security system
the dealer told me i don't have security but the red key light comes on when i'm coasting at 40 down a hill. then goes away after moving from a complete stop.
where is the module located? and does anyone have pictures? where do they usually hide the fob if they don't put it on your key chain.
i want to take it to the dealer but it's so hard to prove unless i'm running 40mph coasting down a hill and they are watching, i guess i can record it on video. i can just imagine them saying we can't find the problem even diagnosing the bike's computer.
i've checked the other threads and i have no other issues with the bike except the above.
according to the manual-
service: a key icon that remains illuminated longer than four seconds indicates that service of the module is required
which brings me back to, i have no security according to the dealer but if i can locate the module then maybe they are wrong. plus i was coasting for definitely more then 4 seconds.
Old 08-14-2009, 10:04 AM
shimmon's Avatar
shimmon
shimmon is offline
im not 100% sure here... but i think your bike may be throwing trouble code (DTC).
Old 08-14-2009, 01:05 PM
fox4's Avatar
fox4
fox4 is offline
The factory security is located above the ECM under the seat if the bike is equiped with it I do believe. I also believe there are pictures of it in all the pictures of the ECM tray in the service manual. If that is the same thing that you are refering to?
Old 08-14-2009, 01:20 PM
manborn's Avatar
manborn
manborn is offline
can you elaborate a little bit?
Old 08-14-2009, 01:22 PM
manborn's Avatar
manborn
manborn is offline
damn, i've only got the owner's manual but i'm referring to the security module itself, the brains of it. also do they just hide the fob right beside it if they don't put it on your key chain?
Old 08-14-2009, 01:52 PM
fox4's Avatar
fox4
fox4 is offline
Yeah what I am talking about would be the brain of the security system. If the bike does not have security the only thing sitting in the ECM tray under the seat would be the ECM and the wire harness that plugs into it. If the bike does have it then there will be another small box that sits by the ECM in the ECM tray under the seat.
I've never heard of them hiding the fob on the bike. My dealer rubber bands them to the handle bars.
Old 08-14-2009, 02:40 PM
figjamb's Avatar
figjamb
figjamb is offline
I'm with shimmon on this one. BTW, I think you are looking for the factory security system that you ain't got. FOB hidden on bike=worthless. Don't make sense. Just my 2.
Old 08-14-2009, 03:18 PM
nevets61's Avatar
nevets61
nevets61 is offline
Sounds like DTC code.. procedure to read codes are in the manual. Don't remember it off the top of my head. DTC are fault or trouble codes that the ECM registers if there is an issue noted in the system, ie. bad sensor, ect.
Old 08-14-2009, 05:25 PM
manborn's Avatar
manborn
manborn is offline
sorry, what was i thinking. but it did it again today, normally i coast and down shift according to my speed but i down shifted all the way to N and coasted 40mph - sure enough at complete stop (bottom of the hill) red light comes on and goes away when i move.
Old 09-11-2019, 09:34 AM
coyotedata's Avatar
coyotedata
coyotedata is offline
Deleted
Quick Reply: location of security module or smart security system
