Started SE 113 Build
Old 08-03-2009, 11:14 AM
echo4tango's Avatar
echo4tango
echo4tango is offline
Default Started SE 113 Build
well after much debate I decided to go forward with the 113 SE race engine build. The parts have finaly arrived from Moco and the engine is already torn down. so now comes the task of case boring and assembling the engine. I will keep everyone updated as much as i can about any problems that arrise during the rebiuild.
Expected completion date AUGUST 10 2009
Old 08-03-2009, 11:18 AM
Biggzed's Avatar
Biggzed
Biggzed is offline
Are you building this yourself, or having a shop do the work?
Zach
Old 08-03-2009, 11:32 AM
echo4tango's Avatar
echo4tango
I am doing the build with some help from a friend who has a rebuild shop.
Mission Objective for today= Case boring
Old 08-03-2009, 12:38 PM
Big L's Avatar
Big L
Big L is offline
Take pictures along the way if you think about it.
Old 08-03-2009, 06:40 PM
bigjimhp's Avatar
bigjimhp
bigjimhp is offline
Good Luck
Old 08-03-2009, 08:57 PM
FastBagger07's Avatar
FastBagger07
FastBagger07 is offline
You are going to build up the lower end also?I hope.A stock harley crank and bearings is well known to be a little on the weak side,ya know.
Old 08-03-2009, 10:17 PM
jackinthebox's Avatar
jackinthebox
jackinthebox is offline
good luck with build sure it will turn out great
Old 08-03-2009, 10:28 PM
ranman469's Avatar
ranman469
ranman469 is offline
cool! keep us posted with pics also please
i want to do the 113 race. i don't have the skills so to the dealer for me.
Old 08-04-2009, 08:37 AM
echo4tango's Avatar
echo4tango
alright ..cases bored finaly. that was an experience to say the least. unless you know someone who has done that before I would not recommend doing that on your own.
of course went with the Timken bearings and stock crank. i will not need much crank work since the bike only has 600 miles on it . the 09 cranks are pretty damn strong. For the price balancing the crank insnt needed unless running the engine over 6000 rpms for extended amounts of time. However having it tured and welded is well worth the price.
well so far so good..
next mission objective -getting the case back in the frame
--this make take a 6 pack and some tequila--
Old 08-06-2009, 02:16 PM
echo4tango's Avatar
echo4tango
Finaly sometime off from work. Okay here is what has happened so far. Engine cases bored and crankshaft sent our for trueing and tig welding. Awaiting return of crankshaft. The company is back logged 4 days and will not be able to get it back to me untill the 14th.
Information gathered over the course of this build has led to some interesting findings.
1-Timken bearings are not 100% necessary unless going to a high Tq motor
2-The stock bearing is able to handle up to 100h/100tq
3-Cast Flywheels are not as strong as the Forged BUT will work in big motors if they are trued and welded.
4-If nothing else is done to the crankshaft at least true/weld it =cheap insurnace for big motors
Next mission objective- Wait on crankshaft
Quick Reply: Started SE 113 Build
