front brake buzzing sound
Old 08-03-2009, 09:15 AM
FrankT's Avatar
FrankT
FrankT is offline
Default front brake buzzing sound
guys,
I'm looking for some validation here. Whenever I apply my front brake, I hear a buzzing sound the whole time (until I release the brake). This is more obvious when I am going at higher speeds. The bike stops fine but the sound is bothering me. I had the dealer check it out and they told me that this was normal due to the new type of brake material that is used in order to be environmentally friendly. My bike is an 09 Fatboy. Just wondering if the dealer was blowing smoke or if any of you guys hear the same thing. I should add that the brake pads are stock and I have a stock exhaust and the bike only has 1400 miles on it. Any info would be appreciated. Thanks.
Frank
Old 08-03-2009, 09:20 AM
jed1069's Avatar
jed1069
jed1069 is offline
Mine sounds about the same mine is just more noticeable at slow speeds. Brakes on 09 Fatty sure suck compared to my r6 but you will get used to it.
Old 08-03-2009, 09:25 AM
Theo's Avatar
Theo
Theo is offline
I have the same problem. Sounds like a cricket or something. I read that it could be caused by a burr in one of the holes on the brake rotor that the brake pad goes over. So it shouldn't be a problem.
Old 08-03-2009, 09:28 AM
Mark g's Avatar
Mark g
Mark g is offline
Originally Posted by FrankT
guys,
Frank
Ask your dealer why the rear doesn't do the same? It does seem to be normal,but the excuse they gave you is hilarious!!!
Floating rotors and better aftermarket pads will provide much better braking and it's a relatively cheap mod
Old 08-03-2009, 09:56 AM
FrankT's Avatar
FrankT
FrankT is offline
MarkG,
The dealer told me that the back will make the same sound but that I would not hear it because the noise is behind me.
Frank
Old 08-03-2009, 10:03 AM
oct1949's Avatar
oct1949
oct1949 is offline
Yep normal, just ignore it and after a while You wont notice it
Old 08-03-2009, 10:09 AM
kkinderen's Avatar
kkinderen
kkinderen is offline
My 03 FB has been doing it since day 1. I've tried a few different pads (didn't change the rotors) and it is still there. Seems to be very common and I don't think it is an indication of a problem. Sounds almost like a Cicada.
Old 08-03-2009, 10:17 AM
yep's Avatar
yep
yep is offline
Account Suspended
mine makes a whoosing noise till the brakes are applied . kinda flip flop from yours ... no problem braking
Old 08-04-2009, 07:29 AM
tk353's Avatar
tk353
tk353 is offline
i had the same and thought it was normal. the last pads i heard the noise but felt it too and the dealer said the wheel bearings were bad again and now i dont feel any vibration and the buzz is ever so slight.
Old 08-04-2009, 08:07 AM
av8or's Avatar
av8or
av8or is offline
Yep same sound on my 09 FB.
Quick Reply: front brake buzzing sound
