Front fork oil capacity 2005 Road King
Old 07-22-2009, 06:49 PM
Hamdog's Avatar
Hamdog
Hamdog is offline
Default Front fork oil capacity 2005 Road King
Can someone please help?
I'm changing the front fork oil in my 2005 Road King. My manual is not too specific- it gives capacities for 2002 and 2001- but not for a 2005. It is the right manual. Is it 11.1 or 10.8 or 9.2 oz.? I can't find it any where.
It is not a cartridge type.
I am going to vacuum the oil from the fork.
Please help.
Thank you.
Old 07-23-2009, 12:18 PM
kickstandkaddy's Avatar
kickstandkaddy
kickstandkaddy is offline
Collections Hold
2007 SE Road King
I changed oil and took the forks apart "Easy stuff"
I cleaned everything and used 11.0 oz and used transmission fluid was the oil of choice
I am a old Motocrosser
HD wants to much money for there oil
Old 07-23-2009, 06:11 PM
stroker1948's Avatar
stroker1948
stroker1948 is offline
Why don't you go to your local dealership, purchase new drain screws with gaskets along with the HD fork oil and pour 11.1 ozs into the forks. Do it the right way and for gods sake don't use transmission fluid. Ever wonder why it's called transmission fluid and fork oil ?
Must be a differance in the chemical makeup and viscosity. Do it right, or don't do it at all.
Stroker
38 years exp. repairing Harleys.
Old 07-25-2009, 05:55 PM
Hamdog's Avatar
Hamdog
Hamdog is offline
Thank you.
Old 07-25-2009, 07:44 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 8,482 Likes on 4,605 Posts
Transmission fluid has been used in forks on motorcycles for at least the 40 years I have been riding, it is the equivalent of 15w fork oil....The fork oil that is in the container I bought at the Harley dealer looks and smells just like...Automatic Transmission Fluid...
I do agree with stroker that you should remove the drain plugs and change the fluid the right way.
Vacuum it out? The wife is gonna be pi$$ed when she cranks up her vacuum...
Old 07-25-2009, 07:55 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Originally Posted by kickstandkaddy
2007 SE Road King
I recommend NEW transmission fluid as the oil of choice...
Mpderksen
03-01-2014 12:24 PM
ballbreaker69
05-25-2013 02:05 PM
Chopman
01-30-2013 06:37 AM
PDDGM
04-05-2009 09:49 AM
bbissell
08-13-2008 09:27 PM
Quick Reply: Front fork oil capacity 2005 Road King
