1995 XLH1200 oil change question...
Old 07-20-2009, 10:24 AM
Jim Dawson's Avatar
Jim Dawson
Jim Dawson is offline
Default 1995 XLH1200 oil change question...
I recently bought a 1995 XLH1200 and want to change the oil. Please don't tell me to buy a service manual as I have one on order.
How much oil in the crankcase and how much in the primary?
I used to have a Sportster but I don't remember the quantities.
Thanks,
Jim
Old 07-20-2009, 11:18 AM
drum412's Avatar
drum412
drum412 is offline
crank will be a little under 3quarts, and primary pretty much right about 1 qt, for proper primary level pull the clutch inspection cover and with the bike upright, oil should just come up to just touch the bottom of the clutch diaphram spring.
Old 07-20-2009, 11:35 AM
Jim Dawson's Avatar
Jim Dawson
Thank you very much, just what I needed to know.
Old 07-20-2009, 08:07 PM
Bentwrench's Avatar
Bentwrench
Bentwrench is offline
Default Primary Oil Change
If after the primary oil change you experience some clutch drag that wasn't there before, the oil level is probably a bit too high. Take out a couple of ounces. Through experience I've learned that the primary on my 96 Sportster takes right at 29 ounces.
Old 07-20-2009, 08:16 PM
Jim Dawson's Avatar
Jim Dawson
Thanks for the tip.
Jim
P51Driver
05-19-2013 09:23 PM
manny10
Shovelhead
06-19-2012 04:51 PM
Big Sled
05-13-2012 07:55 AM
rookie racer
05-20-2010 07:18 AM
JMSporty
05-27-2007 09:06 PM
Quick Reply: 1995 XLH1200 oil change question...
