baffle removal
Old 05-25-2006, 02:31 AM
crager013's Avatar
crager013
crager013 is offline
Default RE: baffle removal
The SE IIs have a wider diameter than the stock and they look a lot better.
Old 05-25-2006, 02:34 AM
crager013's Avatar
crager013
Oh and one more thing, if you have to break the welds on the stocks to get out the baffles, you cant easily put them back in if needed for an inspection as you can on the SEs with a simple screw.
Old 08-01-2006, 01:02 PM
Sporty12C's Avatar
Sporty12C
Sporty12C is offline
I have no clue where the baffles are even located, I have been trying to find out, but cant locate any info. I have the tapered exhaust on my 06 1200c and would like to remove the baffles. I have read on here about drilling, and some people hammering and so on, but how in the hell am i going to drill out the baffles if i have a tapered exhaust system? Anyone who has done this already help me out, im a bit clueless on this topic, but want to get some real sound from my bike.
Old 08-01-2006, 01:53 PM
Shannon's Avatar
Shannon
Shannon is offline
You really need to search other threads for "baffle removal", "drilling baffles", etc. The baffle is smaller than the small end of the taper. The circular weld that you see on the end of the muffler is holding the baffle in. You either drill it out with a 1 3/4" holes saw or cut it out with a plasma cutter. I did the hole saw and had no problems. Took less than 30 minutes. I took the bolts out of the front muffler to pry it out far enough to get my drill in it.
It is unbelievable how good it sounds. I figured it would have a raspy sound but it sounds just like a harley now.
Old 03-28-2007, 07:47 PM
motorcycles H/D's Avatar
motorcycles H/D
motorcycles H/D is offline
try this site, www.xlforum.net.then when on site search for [the cronk mod]for standard pipes.the testemonials to this mod are all good.[does not work if standard pipes have a CAT in them].hope this helps.
Old 03-28-2007, 11:29 PM
hawkeye1734's Avatar
hawkeye1734
hawkeye1734 is offline
what did you guys do with the exhaust packin?
Old 03-28-2007, 11:37 PM
Dallastx's Avatar
Dallastx
Dallastx is offline
I have done it on 4 different bikes. Takes a 1-3/4 metal hole saw bit and lots of lube. There is no packing. Just a 18 inch baffle.
04ctd
Milwaukee Eight (M8)
25
09-06-2023 02:44 AM
Teardrop
04-15-2012 09:47 PM
brenn
12-11-2010 10:39 AM
dyna-rider
11-24-2009 04:26 PM
ccmedic1130
05-06-2007 03:54 PM
Quick Reply: baffle removal
